Mice getting inside
Old Oct 16, 2020 | 07:10 AM
Dweber85rc's Avatar
Dweber85rc
Mice getting inside
So I have mice getting in my garage and also getting into my excursion. I'm working on finding how they are getting in from the garage, but where would be the most likely spot they are getting into my excursion from?
Old Oct 16, 2020 | 08:51 AM
ASFC27FTFBQ's Avatar
ASFC27FTFBQ
OK, this is just me, but I have two (2) solutions:
My father-in-law had a 2100 sq ft shop I cleaned out a couple of years ago. I found three (3) snake skins and 16 dead rats. Never found any snakes.
I have my own approach:
I work from the outside before they get in. I got a cat.
Laugh all you want, but I don’t have ANY rat problems. Come to think about it, I don’t have many squirrels, either.
Old Oct 16, 2020 | 09:21 AM
mecdac's Avatar
mecdac
Dryer sheets like Bounce.
Old Oct 16, 2020 | 09:22 AM
Dweber85rc's Avatar
Dweber85rc
I think I figured out where they are getting in. I have a floor drain that exits outside and a couple of the slats on the drain cover were broken off. It was maybe 1/2 an inch wide. I wouldn't think they could fit through that but I have no idea where else they could be getting in at. I wrapped the end of the pipe with window screen as a temporary solution until I can get a different cover. I went through keeping them out of my jeep in the last couple of weeks when it was parked outside for a few days on and off and had found vent panels in the back near the bumper that were open and covered them with wire mesh. Now I'll have to do the same for the ex I guess.
LandR's Avatar
LandR
They need 1/4" gap to enter a vehicle. SO it could be through any grommets in the firewall. Could be through rotted seals. Could be through drain tubes.
We battle mice in our antique cars. Stored in a climate controlled workshop.
Old Oct 16, 2020 | 11:08 AM
alloro's Avatar
alloro
Mice will chew through the screen like it's candy. Steel wool stops them dead in their tracks, so you could stuff some in the end of the pipe, at least until they find a new place to go hang out.
Old Oct 16, 2020 | 02:00 PM
Kapusta's Avatar
Kapusta
We have a cat too. She stays in the garage over night. I haven't seen any signs of mice in the last 10 years we've had her. She'll catch mice while she's outdoors too. She's even caught a few small rabbits while outside.
Old Oct 16, 2020 | 07:47 PM
DSMMH's Avatar
DSMMH
I use the TOMCAT rat and mouse killer blocks in my 6.0 X. Every Fall before the weather gets cold, I wire tie a block to a battery cable on each battery. I check the blocks periodically and sure enough they start to disappear. You see once they get inside the X or under the hood, they need food. So they will comb the whole vehicle and finally find the TOMCAT. I usually have to replace both blocks once over the winter. I do this to my X, Dodge Charger Hellcat, C6 ZR1 Corvette and my go fast boat.
Ed
Old Oct 16, 2020 | 09:13 PM
superdave02f552's Avatar
superdave02f552
on all 6 of my fords ive had/ have for one reason or another the clutch pedal plug (its there on the EX too) in the firewall was out when i bought them. that plug seemed to be a highway that attracted mice.
Old Oct 17, 2020 | 05:58 AM
01__Excursion's Avatar
01__Excursion
I was walking by the 5.4 I have on concrete my driveway, which isn't used due to a rod knock. I noticed a small pile of dried grass clippings sitting on top of the front pass wheel non 4X4 center cap, and I thought since this side is not facing the lawn something is off here, I reached down to touch it and saw a tail disappear into the center cap. I noticed the grass was in front of the pry-bar slot, which is maybe a 1/2".?
Old Oct 17, 2020 | 09:22 AM
ToolmakerRob's Avatar
ToolmakerRob
I know this doesn't help for directly in the vehicle but in my shop I have a few of the "buckets of death" as I call them setup. They are basically a pail with anti freeze in the bottom and have a can mounted horizontally with an access hole on one side and peanut butter on the rolling can on the far side. I have two at my cottage as well which is winterized and usually end up with a dozen mice in the bottom of the pails.
At least it would eliminate them in the shop.
Rob
Old Oct 17, 2020 | 08:09 PM
SmackDaddy's Avatar
SmackDaddy
I keep my bengal tiger in my Excursion. No mice.
Seriously though, they get in through the firewall by the steering column.
Old Oct 18, 2020 | 08:08 AM
Dweber85rc's Avatar
Dweber85rc
I have a bucket trap set up in my garage and nothing has got in it. So they must have been getting in through the floor drain. Ill have to get a new drain grate this week and crawl around under the truck with a flashlight and see what I see
Old Oct 19, 2020 | 06:59 AM
Matt M, PA's Avatar
Matt M, PA
Our cats were watching the door to the attached garage a couple winters ago. I never saw a mouse, but found a towel chewed up and pull of mouse poop. Thankfully, they stay out of the cars in the garage.
What I finally found was that the garage door's seal was failing/fraying at the edges. I replaced the seal, and if evidence is any indication...haven't had another mouse in the garage. I was surprised at the small gap that they must've been getting through.
Old Oct 19, 2020 | 10:40 AM
jasonodsky's Avatar
jasonodsky
+1 on the Bounce dryer sheets. Use the original scent. Put them under every seat cushion. I did that with my travel trailer every winter and never had mice in it or take up residence. Adding the bucket traps is a good thing too. Might need more than one of them if the shop space is large.
Jasonodsky
pkthomas
Nov 28, 2017 08:52 PM
IB Cristina
Newsletter Archive
Jul 9, 2015 02:47 PM
Ford F-250
Oct 4, 2012 07:36 PM
Steina
Nov 28, 2006 10:52 AM
