2020 running boards
Old Oct 14, 2020 | 03:51 PM
ArmyRover's Avatar
ArmyRover
2020 running boards
Ok so I have read and read and the general consensus seems to be they work. I have tried them with the f250 brackets, Excursion brackets and I can't seem to line up anything what am I missing.
Are folks just using self tappers to make new holes in the boards?
Old Oct 14, 2020 | 08:16 PM
Lance Helmert's Avatar
Lance Helmert
Pictures would help, but I would drill the holes you need in the new brackets. Use the old ones to mark where the holes go or make a cardboard template. There are a couple different spots to mount them under the EX, you just need to move the U-nuts or get new ones. I can't remember if just the middle can be moved or if they all can.
Old Oct 15, 2020 | 09:14 AM
EXSwap's Avatar
EXSwap
I have a set that I haven't mounted yet, but I'll be using the factory 2020 brackets so they hang a little lower for the short folks in my life. Plan is to use riv nuts to mount them using the bottom flange of the rocker and through the inner rocker for the top mounts. Holding them up by hand, seems like it'll work.
Old Oct 15, 2020 | 09:18 AM
agsmv1's Avatar
agsmv1
I have some off a 2017 or 2018, I just self tapped them on to the original brackets.
Old Oct 15, 2020 | 05:34 PM
ArmyRover's Avatar
ArmyRover
The offset on the brackets didn't look very feasible unless you are adding spacers. I ended up using the original Excursion brackets lined the boards up where I wanted them to sit, drilled and tapped them.
Next project will be fitting that ranch hand brush guard. Found so many deals in Texas for this thing
Glocklover72
Jul 30, 2020 05:06 PM
RedRage
2015 - 2020 F150
Apr 26, 2020 09:36 AM
Steelhant
Jan 26, 2020 03:41 PM
Scott Akers
2009 - 2014 F150
Sep 3, 2019 08:51 PM
reesestewww
Nov 7, 2017 10:22 PM
