FRAME REPAIR PATCH??
Old Oct 14, 2020 | 02:44 PM
JPIECHOC50's Avatar
JPIECHOC50
1993 f150 4x4 I'm in the middle of a frame-off. of course I notice the frame is cracked behind the steering gear like alot of them are. the donor truck I have is cracked too!! I've already put many weeks worth of work into getting this frame ready to be rust-proofed and repainted, and bought almost every bracket and mount there is to bolt onto the frame.
the crack is about 3 inches long and goes right thru one of the steering gear bolt holes. I've heard this can be welded and the steering gear can also reinforced with a bracket to take off the stress. but my question is, is there a frame repair bracket out there to put on the outside of the frame rail for added strength? I cant seem to find one and figured there would be one considering this is a common problem. any help would be appreciated
Old Oct 14, 2020 | 02:49 PM
JPIECHOC50's Avatar
JPIECHOC50
1993 f150 4x4
Old Oct 15, 2020 | 09:43 PM
Festus2's Avatar
Festus2
My Grandson's 96 F150 had cracks at the steering box bolt holes and a crack at the bottom where frame halves were welded together. We had to cut an access hole on the outside to put additional weld on the bottom crack from the inside. We drilled the ends of the cracks before welding to keep them from spreading further and ground a notch in the cracks before welding. After welding we ground the welds flush at the bolt holes. Found out that a rivet had sheared at the bottom of the engine crossmember that probably contributed to the cracking. We replaced it with a 1/2" grade 8 bolt and welded a reinforcement piece between the frame bottom and the crossmember bottom. We also added a piece of 3"x3"x1/4" angle iron mounted between the brackets for the sway bar mounts on the frame. We were hoping this would help to stiffen up the front of the frame to help prevent future cracking. Good luck!
Old Oct 15, 2020 | 10:27 PM
GoinBoarding's Avatar
GoinBoarding
The above post sums it up well. I just wanted to reiterate the importance of adding some kind of cross member (like the 3x3 angle iron described above). There's a pattern in these failures, where trucks that had a front sway bar tend not to crack, while those without do crack. The primary difference is that little bit of extra frame strength from the sway bar mounting bracket that acts like a frame cross member.
Old Oct 19, 2020 | 12:22 PM
JPIECHOC50's Avatar
JPIECHOC50
THANKS FOR THE REPLIES GUYS! I figured i'd have to make some kind of patch but was really hoping they made a bolt-on somewhere. So i'm gonna weld it the best I can, add some reinforcement and crossmember it.
If i wanted to add a sway bar I figure i'd need some brackets for the area by the coil springs, and the rest of the hardware that comes with the sway bar kit. anything else to it?
anyone have any idea about the steering gear pitman arm bracket they sell, is that necessary? btw im running 31" tires on stock suspension
Old Oct 19, 2020 | 12:38 PM
GoinBoarding
The OEM sway bar setup has a thin gauge cross member ahead of the axle (bolts to welded on brackets on the frame just rear of the frame crumple zone). Under the coil springs are spring seats with front facing tabs to connect sway bar links. Those spring seats may need to sourced from a junkyard, I'm not sure. Aftermarket solutions might be totally different.
I don't think any kind of steering gear brace is needed. My truck does not have one. It has had that front sway bar cross member, as well as a beefy front hitch, forever. 313k miles, gets used pretty hard in the WY & CO mountains, 33" tires.
Old Oct 30, 2021 | 01:25 AM
PRIMERED79 SHORT BED's Avatar
Did you figure out a way to brace the frame in the front? I'm fixing to do some reinforcing to my 92 f150 frame this weekend.
clarkbre
Oct 29, 2021 04:11 AM
bartspedden
15
Mar 26, 2004 07:07 AM
nickmobile67
Oct 28, 2003 06:32 AM
wildjon300ci
Feb 13, 2003 08:17 PM
tetraruby
Nov 12, 2001 02:48 PM
