Tea kettle sound
Old Oct 18, 2020 | 08:25 AM
  #31
Fuzzpuss's Avatar
Fuzzpuss
Originally Posted by SmackDaddy
That is from thermal expansion, that’s why when it’s cooler out your pressure rises more after warm up. Mine still does this after all my fairly extensive rebuild work. Right now it’s about 60 in the morning and starting cold my manual 30psi coolant pressure gauge hits 9-10psi after warm up. If I romp on it the pressure will rise a couple of psi while on the throttle hard but return to 9-10psi when I start driving normal again. The trick to see if it’s truly just thermal expansion is something Jack mentioned in this thread. Once the pressure stabilizes get out and carefully vent the cap and continue driving. If the gauge stays around zero your heads have no combustion gas leaking into the coolant passages. If the pressure rises again you have some leak by.
Yeah, my pressure doesn't drop unless I shut-off the engine, or release it at the degas bottle cap. In either case the pressure goes back up fairly quickly. This discussion had me hoping I had dodged a bullet. Better luck next time!
Can someone please explain how ambient temps affect thermal expansion of engine coolant?
Old Oct 18, 2020 | 10:23 AM
  #32
SmackDaddy's Avatar
SmackDaddy
Just as with tire pressure, when ambient temperature drops your tire pressure is reduced, when temperatures rise your tire pressure increases. The same is true with your engine coolant. Going from coolant temperature of 50 degrees and then warming your truck up the coolant temperature increases 140-150 degrees and the coolant pressure rises. Once at that temperature with the truck running and you release the pressure through the degas cap there should not be much more expansion because your coolant is at operating temperature. If it comes back up to 10-15psi after that and you have an EGR delete that pressure is LIKELY coming from combustion gases jumping from cylinder bores to coolant passages. A slight area of head gasket sealing surface is all it takes. There’s only about 3/16” of sealing surface separating combustion gas from coolant passages. I drove my truck for about 35-40k with leaking head gaskets and it would only puke if I really romped it hard. Otherwise when I got on the throttle I would occasionally get the tea kettle sound and see steam on my windshield as the heat and coolant vapor escaped my degas cap. With moderate driving my coolant pressure would maintain just under venting pressure.
One important thing I learned in my field is when compressing natural gas with a compressor to drive gas down the pipeline is that gas can be compressed and liquid cannot. I think the heat is expanding the coolant and compressing the gas in the cooling system.
Old Oct 18, 2020 | 09:58 PM
  #33
Fuzzpuss's Avatar
Fuzzpuss
Thanks for the thorough explanation Mack. Funny thing is, I romp on it all the time and I've never heard the tea kettle or seen steam. It did puke minimally a couple times but that doesn't happen since I started keeping the coolant level low.
I still can't get my head around the temps and pressures thing. In a closed system with gas and liquid (pressure does not exceed degas cap limit in this example) as it heats up the liquid expands and the gas compresses, raising overall system pressure. Say the system is opened, topped off, and closed in the summer when ambient temp is 100 degrees. As ambient temps drop wouldn't you end up with a vacuum in the system, which would offset the delta between the lower ambient temp and engine operating temp, and thereby resulting in no difference in pressure at said operating temp?
The only thing that makes sense is that air makes its way into the system as the system cools so vacuum is never present.
Old Oct 18, 2020 | 11:08 PM
  #34
TooManyToys.'s Avatar
TooManyToys.
It may only seal in one direction.
Smith Shimer
Sep 14, 2020 07:12 AM
Macrosill
Sep 24, 2017 06:24 AM
JPs2003
21
Jun 11, 2011 07:48 PM
TonyPark33
Mar 9, 2011 09:50 PM
Foxtrot35Oscar
Jul 16, 2010 09:52 AM
