trailer running lights
Old Oct 14, 2020 | 08:35 AM
Rise Up!!'s Avatar
Rise Up!!
all my lights work on my trailer with exception of running lights. did an electrical check at the truck side 7 pin and no power to running lights. Checked and replaced fuse 99 which was not blown but changed anyway. Not sure where to go next? 2017 6.7 Super duty lariat
Old Oct 14, 2020 | 08:42 AM
grumblin's Avatar
grumblin
Are your headlights on? I'm sure that's a stupid question but...
Old Oct 14, 2020 | 08:45 AM
Heathmc's Avatar
Heathmc
Get under the truck and pull the connection behind the 7-way plug. There is a common issue (might even have a TSB) with water intrusion there causing corrosion. Check for corrosion, clean it off, and replace the connector with plenty of electrical grease to help prevent it in the future.
Old Oct 14, 2020 | 12:48 PM
mtnguy's Avatar
mtnguy
Funny, my 2017 Lariat F350 also lost the trailer running lights last time pulled. I will check the plug.
Old Oct 14, 2020 | 04:24 PM
Pugga's Avatar
Pugga
Well... this thread is timely. I just got back home from a trip and noticed the running lights weren't working. Brakes, brake lights and directions worked fine but the running lights don't. I just ordered a 7-pin tester to confirm if it's the truck side or the trailer side. It sounds like I'm a couple days behind you with my findings.
Edit: Mine was caused by a blown fuse #99. Replaced the fuse and all is well. Hopefully you figure out what happened to yours!
Old Dec 18, 2020 | 05:01 PM
greensock's Avatar
greensock
Same issue here. 2019 F350 Lariat SRW Tow package. Fuse 99 is not blown and no power to running lights. Any updates from the other posts on this thread?
Smokeat
Nov 17, 2024 05:23 PM
landscapeguy
Apr 13, 2019 04:58 PM
Keith Mathewson
Jul 11, 2018 06:25 PM
Kelpy1
Mar 9, 2017 09:31 PM
iez44
All Things Towing
Sep 6, 2013 02:43 PM
