Crossover line PowerStroke
Old Oct 12, 2020 | 07:12 PM
Smith Shimer's Avatar
Smith Shimer
What benefits does the crossover line between the left and right headstock bring to the PowerStroke engine?
Old Oct 12, 2020 | 09:45 PM
97-psd's Avatar
97-psd
If you do a quick search you will see a couple differing opinions on the topic. The general idea is to equalize the high pressure oil between the heads. The more consistent pressure provides a smoother smoother running engine. Most of the upgraded HPOPs say you don’t need it as the upgraded units balance the pressure so the crossover is not needed.
I installed one one before I installed my t-500 and noticed a smoother idle. I did not bother to remove it when I installed the t-500 and it has not been an issue so I just left it alone.
Old Oct 12, 2020 | 09:56 PM
Smith Shimer
thank you very much friend
Old Oct 13, 2020 | 01:01 PM
Hit Man X's Avatar
Hit Man X
I have had the same experiences as above. Popped an Adrenaline in as old pump lame, just left that pipe. Ha
Old Oct 13, 2020 | 05:26 PM
TheFecalFanatic's Avatar
TheFecalFanatic
@97-psd Hit the nail on the head.
I took this from Riff Raff Diesel's HpX: The crossover is meant to allow excess oil pressure to flow between both heads allowing for better supply to the injectors. By allowing the oil to flow to the opposite head, the issue of pressure spikes are less and allow for a smoother idle.
You can do the same thing theoretically by removing the check valves beneath the stock lines. I still run one even though my HPOP doesn't have the check valves. I figure until it leaks it can't hurt to have equal flow and pressure and not only rely on the HPOP to relieve the pressure.
Dan V
Aug 31, 2019 07:24 AM
fordguy98
13
Nov 28, 2016 10:10 PM
Sous
Ford Truck Parts for Sale
Nov 16, 2016 11:39 AM
Willz74
Jul 31, 2015 07:57 PM
jberylecrider
Offroad & 4x4
Aug 19, 2002 10:22 PM
