Hello all. On my 2019 SD when parking it in my garage shouldn’t it give me a warning when I’m getting close to the wall? I just recently switched garage stalls and I used to back it in and it would alert me when I was getting close to the wall which worked great but when I drive it in it doesn’t do that. I could have sworn when I test drove these the salesperson told me it would alert me of an obstruction in front. Do I have something not set correctly or has something malfunctioned?
Yes I do have that camera since I ordered the Tow Technology. I just went and tested it out. It does work and I can gauge it better to determine how close iam getting to the garage wall. Thanks
Pre Collision is for higher speed use I believe. As was mentioned no front parking sensors for some reason these. You can get aftermarket ones on Amazon that will sound a buzzer, not tied into the Sync system but nice audible. Or front camera is a good option.
That beep is super annoying. I have to shut it off when I start to back up.
personally I just watch the camers. I also put pool water tubes on the wall to get super close. But my wall is a plastic shed. You can kinda see it here. I just glued and screwed it in
