Sponsored by: Auxito
Possibly a bent valve
Old Oct 11, 2020 | 10:43 AM
Hunter Andrews's Avatar
Hunter Andrews
I have a 2000 Ford F-150 with the 5.4 triton motor it is about 1000miles from 200,000 miles. It ended up spitting a spark plug out of cylinder 7 while driving it like a granny l. So I drove it home parked it took all the spark plugs out and coil packs out. Replaced all of the spark plugs and coil packs. Except cylinder 7 was stripped so i put a non fouler kit in it instead of heli coil like I should have only reason for not doing that is because never done one and autozone didn’t have any for my motor. The truck cranks up fine and idles pretty decent all plugs are motor craft except cylinder 7 which is autolite which is what came in the non fouler kit. Was wondering if putting non fouler kit in there would change the compression on the motor. When I rev it up it sounds like a bent valve and when it’s under pressure such as putting in gear it bogs down
Old Oct 12, 2020 | 09:36 AM
alloro's Avatar
alloro
Bent valves don't make noise audible to the human ear. Can you explain what the sound of the noise compares to?
Old Oct 12, 2020 | 11:45 AM
Lime1GT's Avatar
Lime1GT
I would check for engine codes and reset the KAM first. Who knows what the PCM adjusted the fuel tables to with no spark plug in one cylinder.
Old Oct 12, 2020 | 11:49 AM
ford390gashog's Avatar
ford390gashog
Well the non fouler will just blow out. Its probably not even seated all the way. You need to install a timesert and fix it properly. Don't use the helicoil brand kit use the genuine timesert.
leftylucy64
2004 - 2008 F150
Jul 7, 2020 08:26 AM
stapleton2709
Modular V8 (4.6L, 5.4L)
24
Sep 22, 2016 03:52 AM
tjw11235
General Automotive Discussion
Jun 27, 2011 01:22 PM
twelker_04
1997 - 2003 F150
Dec 15, 2009 08:26 PM
