View Poll Results: Whats the stock number of voltage to a coil
Help
66.67%
Help
66.67%
Multiple Choice Poll. Voters: 3. You may not vote on this poll
1995 f150 spark problems
Old Oct 6, 2020 | 06:24 PM
1982f150351w's Avatar
1982f150351w
I have this 1995 f150 5.0 and I keep frying coils in it and I can’t figure out why I’m getting a good ground I’m getting 11.4 volts to the coil is that to low or to high but I can put a new one in and it will run for about 5 minutes and it will die then will not have any spark and I can put a new one in and it will fire right up abs di the same and I just put a black icm in it to new wires distributor new pick up plugs and everything
Old Oct 7, 2020 | 07:17 AM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
You aren't gonna get ANY responses here as this is the NEW MEMBER SIGN IN forum. Take your poll here: https://www.ford-trucks.com/forums/forum62/
Old Oct 7, 2020 | 11:10 AM
1982f150351w
Originally Posted by BPofMD
You aren't gonna get ANY responses here as this is the NEW MEMBER SING IN forum. Take your poll here: https://www.ford-trucks.com/forums/forum62/
thank you!
Old Oct 7, 2020 | 11:54 AM
donjamer's Avatar
donjamer
Moved to appropriate forum
Old Oct 7, 2020 | 12:19 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I hope it doesn’t sway your poll numbers but I voted for help not help.
What does “run it fit about 5 kind” mean? What brand coil? Does the coil get very hot?
coil test:
https://troubleshootmyvehicle.com/fo...gnition-coil-1
nothingbutford
Mar 25, 2002 11:47 AM
