Starting Problems
Old Oct 5, 2020 | 07:53 PM
Dread Roberts's Avatar
Dread Roberts
Starting Problems
Good day, I’m looking for some advice. I have a 2003 F350 7.3 Powerstroke. Typically I have no issues with it starting up. Occasionally when I shut off the motor and try to start it within 5-10 Min it will not start. I have to wait for 15-20 min and then it will start right up. This doesn’t happen all the time. There is no pattern that I can see. Any advice on where to look would be appreciated.
Old Oct 5, 2020 | 08:25 PM
udsuth78's Avatar
udsuth78
Likely culprits are IPR valve or ICP sensor, both are major players in the HPO system. I'd start with the IPR tin nut and wiring pigtail. Nut should be snug not tight, maybe 1/8 turn past finger tight. Then check harness for cuts or soft spots in insulation. The next time it acts up try unplugging the ICP, it puts the PCM into a default setting so if sensor is bad the truck will start. I'd also look for a diagnostics tool. Forscan is the best low buck option I've heard.
Old Oct 5, 2020 | 09:08 PM
Dread Roberts
Thank you I really appreciate it
Old Oct 5, 2020 | 10:41 PM
udsuth78's Avatar
udsuth78
Any time, good luck and let us know how it goes. Never know when your fix helps the next person.
Famer
Aug 5, 2020 10:45 PM
Dkanngiesser
Mar 17, 2020 11:03 PM
tarpy
Dec 23, 2002 10:42 AM
