View Poll Results: Machine with torque plate
Yes- performance build of 450hp+
20.00%
No- performance build of 450hp+
20.00%
Yes- factory build
40.00%
No- factory build
20.00%
Voters: 5. You may not vote on this poll
Machining your FE
Old Oct 2, 2020 | 03:08 PM
dubya TF's Avatar
dubya TF
Machining your FE
Just to pick your brains- would you have your FE (or any other engine) bored or honed with or without a torque plate?
Old Oct 3, 2020 | 10:58 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Personally, I've had 2 FE's, a 289, a handful of Triumph TR7 engines and personally know a few people that have engines running 20+ years later from the machinist that did them all. He never used a torque plate. Did all his own boring in-house. He was a genius, though, if that matters
One of those engines is a high performance 383 Chevy small block build he did for a friend of mine for a '68 Firebird. Full roller. He's gone drag racing with it, and generally just putters around the street now, but he does beat the crap out of it. It's in the 500+HP range.
I'm not saying don't do it, but I'm kinda on the fence about whether it's necessary or not.
On edit: My vote of "No - factory build" means not necessary for a stock rebuild, but if you're going big numbers, definitely.
Old Nov 6, 2020 | 01:53 PM
dubya TF's Avatar
dubya TF
Wow 270 some views and 5 votes. Be honest- how many of ya'll had to look up what a torque plate was? lol
Old Nov 6, 2020 | 02:50 PM
'65Ford's Avatar
'65Ford
I won't say it's necessary 100% of the time but if I'm putting the effort into pulling an engine and re-installing it along with spending money on what ever parts needed and time to assemble then I'm having it torque plate honed. How much does it add to the total cost?
Years ago I got an engine from a large engine rebuilder who did not mention torque plate honing in their procedure. It ran extra hot at idle for the first 500 miles...I guess until it rounded the rough edges. My current engine was torque plate honed and has never run hot.
Old Nov 6, 2020 | 04:50 PM
ford390gashog's Avatar
ford390gashog
The problem is finding a shop that owns a torque plate for a FE. They have them for SBF and all the GM engines but I had to make my own plate 25 years ago! End result I had a .002- 006 change in vertical taper without the plate. With the plate and the block warmed ( A trick I learned from a respected machinist) I was able to control the taper down to .0015 - .0019. This worked really well for me as I was running the then new coated skirts.
Twisted Light
Jan 25, 2008 08:02 AM
LSEYMOUR
Texas Chapter
Jun 8, 2006 09:44 PM
optikal illushun
Sep 17, 2005 11:15 PM
76 F150 Ranger XLT
Jul 16, 2004 09:29 PM
19Ford69
Sep 19, 2003 02:43 PM
