ford f350 2 wheel drive super cab 1992 Ok here is the problem right front wheel at 40 to 50 the wheel wobles had front end align tires balance problm goes away and coms back and the wolble is pretty violent any help would be very appreciated thank you
If it wasn't for your having the front end aligned, my confidence level would be at 90%+ that you have a bad tie rod end or drag link.
But they should not have been able to do a proper front end alignment if this was the case.
. . . huuummmmm. Was it a reputable shop AND an experienced Tech that did the alignment? I'm still suspicious of the tie rod ends. I don't know what else could cause the symptoms you describe except bad suspension (steering) connectors.
