Sponsored by: Real Truck
08 6.4L
Old Oct 1, 2020 | 07:48 AM
Dieselcyrus's Avatar
Dieselcyrus
08 6.4L
Should I flush power steering system.fluid when replacing steering gearbox OR just top it off? I have an 08 f250 with 135k miles.
any advice is appreciated
Old Oct 1, 2020 | 11:17 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I'd say:
1. Run it
2. Drain all the fluid you can as soon as possible after you shut it off
3. Change steering gear
4. Fill and test
5. Enjoy
Welcome aboard!
Old Oct 1, 2020 | 09:09 PM
donjamer's Avatar
donjamer
Moved to appropriate forum..
Old Oct 1, 2020 | 11:02 PM
AK4x4's Avatar
AK4x4
Perform the power steering system flush per the manual, then swap the steering gear, and then a quick second flush. You don't want any old dirt or yuck in the new gear, and just in case the quality of work on the new gear wasn't so great make sure that it doesn't add any contaminants to the system either. Fluid is cheep. Good luck, Russ
Old Oct 2, 2020 | 05:04 AM
Dieselcyrus
Thank you Russ, appreciate the advise. Will do.
DaveinIndy
New Member Introductions
Dec 1, 2006 12:53 PM
deereman2
Nov 5, 2003 05:53 AM
