No power
Old Sep 30, 2020 | 05:25 PM
williamlreidlll's Avatar
williamlreidlll
No power
Hello after pluging in my rear ac controls I started the truck when I turned on the rear fan the truck started to stall. After turning it off it will not start. I get nothing no lights beepes nothing. Tried to jump it and still nothing. Does anyone know whitch one is the main or altinator fuse?
Old Sep 30, 2020 | 06:12 PM
WE3ZS's Avatar
WE3ZS
Will it spin the engine at all? How about with all of the AC controls set to the OFF position? The AC compressor could be locked up making it very hard for the starter to spin the engine over.
Old Sep 30, 2020 | 06:15 PM
williamlreidlll
no its does nothing when I turn the key
Old Sep 30, 2020 | 06:19 PM
WE3ZS's Avatar
WE3ZS
Battery voltage is good?
Check all of your battery and cable connections.
Ensure its solidly in PARK.
Old Sep 30, 2020 | 09:05 PM
williamlreidlll
the battery is good but I did find when I touch the positive battery cable the interior lights came on,, but when I turn the key i get nothing.
Old Oct 1, 2020 | 01:29 AM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
Remove the positive and negative cables from the battery, and use a wire brush to scrub away any dirt/gunt/corrosion very briskly from the inner edges of the battery cables, and also scrub off the battery contacts and reconnect everything making sure it is nice and tight.
Old Oct 1, 2020 | 02:45 PM
williamlreidlll
although the cables did not look dirty that did the trick
Old Oct 1, 2020 | 04:32 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
Maintain your battery cables more often
Old Oct 1, 2020 | 06:50 PM
fordboy67's Avatar
fordboy67
A bit of vaseline on the cleaned up terminals helps keep them from corroding as fast.
Old Oct 1, 2020 | 07:23 PM
01__Excursion's Avatar
01__Excursion
These are usually at the register counters at every auto parts store.
https://www.oreillyauto.com/detail/b.../00911/4776620
04black5.4L
Jul 27, 2012 10:45 PM
grishw1
Jul 18, 2012 08:54 AM
buddy357
Mar 7, 2011 08:24 AM
dpbullseye
Jul 25, 2008 05:28 PM
FishOnTheBrain
Aug 17, 2007 05:29 PM
