Oil & Lubrication
gear oil
Old Oct 21, 2003 | 08:33 PM
bigbrownie's Avatar
bigbrownie
gear oil
hello, I have a 78 3/4 ton and im getting ready to fill both the differentials and manuel transmission . Wondering if anyone had any favorite brands. I was thinking mystik jt-6 My rear end is not limited slip, so I guess regular gear oil will work?in a 5 gallon bucket
Old Oct 22, 2003 | 10:34 AM
TallPaul's Avatar
TallPaul
I would go all synthetics for the manual tranny and differentials, mainly because they are in there a long time. For the crankcase I still stick with dead dino juice (rotted plants, animals, and I suspect a few dead people too ).
Old Oct 22, 2003 | 11:32 AM
jim henderson's Avatar
jim henderson
With the age of your truck I believe that regular gear lubes are what is specified.
I like Valvoline gear lubes just because. For hot climates I would probably go with 90W140 or something like that. For cooler climates probably 75W90 or similar.
If I wanted to baby things and not worry about the lube for a long time, I would use synthetic 75W90.
I have never had a gear train failure due to lubes so I do not know what doesn't work.
Just my opinion.
Jim Henderson
Old Oct 22, 2003 | 11:54 AM
rusty70f100's Avatar
rusty70f100
Mystik JT-6 is a grease. JT-7 is their gear oil. It is an EXCELLENT gear oil. I have read it is used and respected in the trucking industry, and I know that a lot of farmers use it. I also have heard from one of my relatives that is retired from John Deere that they use some Mystik products. So I say go for it.
Old Oct 22, 2003 | 11:26 PM
BigMattXXL's Avatar
BigMattXXL
I do the exact same as Tall Paul - Synthetic for all the extended-use fluids, but dino for the regular oil changes.
XXL
Old Oct 23, 2003 | 12:53 AM
willd's Avatar
willd
Mystic is good stuff, when it changes from red to black, it's time to change. Very easy to remember. I've run rear-ends to 300K miles on mystick changes once every 100K or so. The bearings usually wear out and fail before the gears. I don't think any other oil would do any better. If you have limited slip you just add the tube of stuff from ford or the additive you can get at most parts stores for L/S operation.
Old Oct 23, 2003 | 12:54 AM
willd's Avatar
willd
I forgot, mystic also makes a semi-synthetic. I'm not sure, but I think it is 75-90 W. More expensive, but just as good as valvoline in my opinion.
jadmt
Mar 9, 2026 01:46 PM
95350PS
May 18, 2012 05:57 PM
Louie3
1997 - 2003 F150
Feb 27, 2012 08:34 PM
jimwilsonmasonry
May 13, 2008 08:32 PM
bronco351
Apr 27, 2003 08:05 AM
