Idling issues
Old Sep 27, 2020 | 07:35 PM
victoryvan's Avatar
victoryvan
Idling issues
Hello, I’m having idling it is on my 1986 302 EFI Ford truck. symptoms:
On start up from cold it idles high at up to 2000 RPMs. After one minute it drops to about 1200 or so RPMs.
When I put it in gear the RPMs surge and it moves vehicle forward without giving it any gas.
Driving around it idles somewhat normal but still high.
When I put it in park the RPM surge again. High RPMs in park.
I have thoroughly cleaned the IAC and IAC solenoid plunger. I have thoroughly cleaned out the throttlebody. I have replaced the TPS.
Also, when I disconnect the IAC while it’s running it’s still idles exactly the same with no change.
Can you please give me some troubleshooting steps to continue trying to identify this problem? Thank you
Old Sep 27, 2020 | 07:58 PM
Franklin2's Avatar
Franklin2
It's either sucking air somewhere, or the idle stop screw has been turned in too far.
Old Sep 27, 2020 | 09:10 PM
diggerrigger's Avatar
diggerrigger
Did you set the TPS correctly? Book gives a voltage range but .98 v is ideal. Did you erase the KAM (keep alive memory) after the IAC and TPS work were completed?
On the high idle upon cold starting, check the Thermactor Air Diverter valve located behind the upper manifold by disconnecting the vacuum line and plugging it. If the diaphragm has gone bad, it will be a vacuum leak that lasts for the duration of the TAD signal, 60-180 seconds.
Look thoroughly for vacuum leaks first. Do not adjust the throttle plate screw until you do. Also, don't adjust the screw without referencing exactly where it is now. It is impossible to set with other issues going on.
These engines have a weak gasket between upper and lower intake manifolds. I'd check that next. Check PVC.
If you are confident that you have no leak and want to give that screw a shot, again, be sure to reference where it is now. Write it down! With a warm engine, unplug the IAC then back off the screw a bit at a time and see if the idle drops. You are looking for maybe 500-550 rpm. Close to dying. Plug in the IAC and and with luck you'll settle out at 675-700 rpm. If you got the idle to come down it will still want to hunt. You would need to erase the computer KAM (keep alive memory) by disconnecting the ground lead to the battery and turning on the headlights. After five minutes, hook it back up and start engine. Let it run while the computer works out a new profile.
Old Sep 27, 2020 | 10:34 PM
kenny nunez's Avatar
kenny nunez
High idle
I had the same problem with a 302 and it turned out to be the gasket under the upper plenum.
Old Sep 28, 2020 | 03:05 AM
matthewq4b's Avatar
matthewq4b
Pull the codes first off, lots of info on the net how to do it just get a code reader.
https://www.innova.com/product/detai...ader-1981-1995
If nothing stands out get the old vacuum gauge out, if you have a vacuum leak that will identify it.
victoryvan
Sep 27, 2020 07:59 PM
whitepolarbear12
1997 - 2003 F150
May 25, 2006 09:15 AM
gearheadz80
Nov 5, 2005 02:29 PM
JEV
17
Jun 9, 2005 08:28 PM
maticuno
1983 - 2012 Ranger & B-Series
May 2, 2004 10:24 PM
