Hood blanket
Old Sep 25, 2020 | 05:58 PM
Rainmaker1's Avatar
Rainmaker1
Hood blanket
Had my Excursion in for a trailor hitch replacement which went well. Just before I left to get it done, turning the key only resulted in a clicking sound like a relay. As I was calling for a tow, I tried agai and all of the sudden It started. Well after replacing the starter and alternator, I thought all was ok. The next day, today I discovered the belt was chewed up along one edge. The new alternator had a damaged pulley that trashed the belt.
As I was showing the damaged parts to the shop, I noticed a piece from the belt chewed into the hood blanket.
the shop is accepting responsibility and is replacing the alternator and belt. As far as the hood blanket, they’re trying to source one.
my question, since a new hood blanket will be installed, is there any sound insulation I can put up there under the new blanket?
Old Sep 25, 2020 | 08:18 PM
SmackDaddy's Avatar
SmackDaddy
I’m going to spray under my hood with Durabak along with all the cladding. I removed my under hood blanket a couple of years ago.
Old Sep 25, 2020 | 11:17 PM
Rainmaker1's Avatar
Rainmaker1
Well, I've searched high and low. Apparently no one really makes a good aftermarket hood pad. I found this (. https://www.lmctruck.com/1999-16-for...nsulation-kits )
Has anyone tried these, are they any good? I'm also considering adding something like a Dynamat product. Maybe both. Hasn't anyone done this?
Old Sep 26, 2020 | 05:44 AM
mecdac's Avatar
mecdac
Thumbs up
I likey
Old Sep 26, 2020 | 06:13 AM
WE3ZS's Avatar
WE3ZS
So the truck didn't start, then it did start so you had the starter and alternator replaced......Why both, what trouble shooting was done to indicate that both were faulty?
I think that its great that the shop is accepting responsibility and is covering the damage, but if the shop installed that alternator with the damaged pulley and either didn't notice it or thought that it was OK I would be looking for a new shop........Or at least requesting that whichever knuckle dragger did that job not be allowed near my rig again.
Old Sep 26, 2020 | 06:23 AM
SmackDaddy's Avatar
SmackDaddy
I think I remember a post on this and 87crewdually installed some sheet insulation product under his hood. Search his posts or PM him.
Old Sep 26, 2020 | 06:37 AM
01__Excursion's Avatar
01__Excursion
It's a long shot, but you can call these people and see if they have one.
https://nospartsltd.com/product/yc3z16738aa/
Old Sep 26, 2020 | 03:54 PM
mecdac's Avatar
mecdac
Only challenge I see with this product is: no cut-out for the under hood light.
Old Sep 27, 2020 | 01:54 PM
Rainmaker1's Avatar
Rainmaker1
[QUOTE=mecdac;19497946]Only challenge I see with this product is: no cut-out for the under hood light.
I would think a hole could be cut for the light assembly. The cut edges could be lined with something to keep the material from fraying. So far it's either this or the Dynamat solution. I can't be the only one looking for a solution to the the hood blanket (pad).
Old Sep 27, 2020 | 09:53 PM
SmackDaddy's Avatar
SmackDaddy
White Bear Lake has them.
Old Sep 28, 2020 | 07:32 PM
Rainmaker1's Avatar
Rainmaker1
If you're referring to White Bear lake Ford, I called them and they said not available. If you have different information, please let me know. So far I could only find these two and guess which one the shop wants to pay for...
https://www.detroitmuscletechnologie...-foil-backing/
I would much prefer OEM because it's molded and the one at Detroit Muscle is a flat piece of material pushed into position full of wrinkles.
Old Sep 28, 2020 | 08:01 PM
SmackDaddy's Avatar
SmackDaddy
Well shoot I’m sorry! I looked it up on the WBL website and it let me add it to my cart. Message 87crewdually, I think I remember him using a sheet product to line his hood.
Old Sep 28, 2020 | 09:21 PM
LandR's Avatar
LandR
My ex didn’t come with a hood blanket. i dont think it makes a ton of noise insulation difference on the v10s
Matt M, PA
May 15, 2017 06:06 PM
freeholden
Jan 17, 2010 05:35 PM
fdaugher
May 6, 2009 10:14 PM
nick_wood
General Automotive Discussion
Jul 15, 2005 03:53 PM
Ranger_CN78
1983 - 2012 Ranger & B-Series
Aug 21, 2004 11:46 AM
