Manual Hubs - Winter is coming
I have a 2003 SUperDuty 4x4 5.4L 4.73 Ex-Cab Auto.
I live in the Northeast. I want to be able to lock those hubs in November and leave them that way until February. The problem is I have noticed a little binding with just the hubs locked without being in four wheel drive. I have noticed the binding at slow parking lot speed with a fairly sharp turn mostly.
Is this something I need to be concerned about?
thanks
Tom
thanks
Tom
that binding is normal for trucks with u-joints on the front axle, when you lock the hubs in every thing on the front axle spins whether the transfer case is in 4wd or not; The binding when you turn sharp is from the two halves of the u-joint rubbing together as it rotates around. you'll notice it more on a hard surface than a loose one because the tires can't slip when the u-joint binds. There isn't much you can do to stop it ,except unlock the hubs if you need to turn really sharp, or don't turn the wheels that sharp. The only thing you want to try to avoid is mashing on the gas in 4wd when the u-joint is binding because it could damage the u-joint if done alot.
I usually leave the hubs unlocked unless I expect bad conditions on my drive. Less wear and tear and a bit better mileage when unlocked.
If I do expect bad conditions I will lock the hubs and keep it in 2WD until I need 4WD. Then if I need 4x4 I slow to below 35mph and usually I put it in neutral and coast and slide it into 4x4, then put it back in drive. Seems to be less shock on the drive train and easier to engage this way.
Even in good driving conditions you should lock the hubs and drive in 2WD for 10 or 20 miles every few months just to get the fluids circulated. Note that locked hubs will cause more rumble and noise while driving even in 2WD.
As far as binding, I haven't noticed, but would guess there is extra resistance due to the extra moving parts.
Good Luck,
Jim Henderson
Good Luck,
Jim Henderson
