Offroad & 4x4
Tires
Old Sep 24, 2020 | 01:18 PM
backwoods redneck's Avatar
backwoods redneck
Tires
So i have a 95 f150 xl. I plan on putting a 6 inch lift on it, what are the largest tires i could fit on it. It currently has 235/ 75r15 before the lift. I also plan on getting new rims so they can be wider. Also it has a 5.0 and is 4wd 1/2 ton.
Old Sep 24, 2020 | 01:21 PM
ford390gashog's Avatar
ford390gashog
I would be more concerned with what gears it has first, these trucks were anemic stock. If you go with a 35" tires you will need some 4.56 gears.
Old Sep 25, 2020 | 05:22 PM
backwoods redneck
do you know how much that might cost to regear it to 4.56? And would 4.56 or 4.88 be better?
Old Sep 26, 2020 | 07:26 AM
tjc transport's Avatar
tjc transport
i ain't rite
with a 6 inch lift, you will easily be able to fit a 33X10.5 tire. a 35X12.5 should fit also.
but like said, you will need at least a 4.56 gear set for the 35's
Ford Master
Sep 3, 2020 06:54 AM
BigRy
Sep 5, 2009 09:41 AM
fordman95
Offroad & 4x4
Jul 16, 2002 12:47 AM
cmr
1997 - 2003 F150
Jun 28, 2000 08:56 PM
