Oil Filter mount
Old Oct 21, 2003 | 05:09 PM
Mike G's Avatar
Mike G
Oil Filter mount
Ok folks, just got back from a wonderful trip through my favorite salvage yard and stumbled across something that sparked an interest. The is a 65 galaxie FE with the front half of the motor stripped off. My eye was drawn to the vertical mounted oil filter. Is there a reason why these were not offered on the trucks and why should I not go back, not that I will be for other parts anyway... and get that puppy for my truck. I always prefer to keep the oil in the filter than spill it all over the ground come change time.
--MG
Old Oct 21, 2003 | 05:54 PM
BB's Avatar
BB
The vertical filter adaptor won't work in the 4x2 pickups, the filter will hit the crossmember.
Barry
Old Oct 22, 2003 | 10:21 AM
Mike G's Avatar
Mike G
Awww s#!% I was hoping to keep oil off my floor....
Thanks!
Old Oct 22, 2003 | 11:04 AM
William's Avatar
William
I jam a plastic funnel up there and turn the filter back a bit and have a beer while it drains into the drain pan. Good excuse for having beer.
Old Oct 23, 2003 | 07:18 AM
baddad457's Avatar
baddad457
Thanks!
The oil filter adapter from the 70's 4wd pickups will also fit 2wd trucks, and while not pointing the filter straight down, does point it down and forward at a 45 degree angle.
Old Oct 23, 2003 | 09:22 AM
Mike G's Avatar
Mike G
Perfect excuse to go shopping again!
Old Oct 23, 2003 | 09:38 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I have a '74 highboy 4x4, and the filter hangs straight down. Original, too...
ak
Old Oct 23, 2003 | 10:16 AM
Putt's Avatar
Putt
You could always get a remote oil filter setup and mount the filter wherever you want.
Old Oct 23, 2003 | 10:24 AM
baddad457's Avatar
baddad457
I just sold a 45 degree adapter on ebay last week for $34. I found it on a mid 70's 1 ton 2wd. Don't know if the motor was original to the truck though cause it also had a rear sump 4wd oilpan too. The part# was D6TE-6881-AB
Old Oct 23, 2003 | 11:55 PM
Putt's Avatar
Putt
I think the 45 deg adapter came on 460 engines in 4X4's during the 70's. It would help angle the filter down some.
superrangerman2002
6.7L Power Stroke Diesel
17
Aug 30, 2014 06:13 PM
cubman61
Modular V10 (6.8l)
25
Dec 6, 2012 11:55 AM
Xclimation
Jul 26, 2012 11:16 PM
wildcard30
Oil & Lubrication
24
May 10, 2004 11:30 PM
crookit
Bronco II
Mar 27, 2002 11:27 PM
