Rough Idle
Old Sep 24, 2020 | 10:18 AM
z31freakify's Avatar
z31freakify
Originally Posted by SuperchargedPSD
So shimming an injector to gain armature to body top clearance is too band aid an injector when it starts rough cold and runs fine once warmed up. This is due to the cold oil causes the armature plate to stick (stiction) to the body top. Unfortunately shimming an inector will not fix a worn upper poppet valve seat. The cheapest way to fix this issue is to use good core injectors and pull apart the top of the injector and swap poppet valve and upper top and or seat parts. There are also shims for the upper seat. This can be carefully accomplished without removing the injector. You would pull the solenoid off then the armature plate then the 4 body top screws and the poppet valve and spring will be accessible. The only other way I see to limp this issue by is to pull the thermostat and run without one. The downside is the engine will take much longer to warm up (no cab heat) and run substantial cooler. This will keep oil temps cooler and hopefully allow it to hot restart. I have ran 7.3s with stuck open thermostats before.
Great info SCPSD.
Old Oct 1, 2020 | 01:39 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
I would also suspect very worn injectors with mileage 300k+ and your symptoms.
95schauf
Mar 2, 2013 09:39 AM
Epd444
Jun 1, 2008 09:45 PM
lifted_01_SD
Apr 25, 2006 02:42 PM
