ZF5 swap
Old Sep 21, 2020 | 03:17 PM
Hood_stackeez's Avatar
Hood_stackeez
ZF5 swap
Hello, I am about to swap out my 4r100 with the zf5. I have just about everything I need but I am unsure of the driveshaft. The zf5 is a 96 and the truck is a 2000. So if anyone knows which one I need please respond!! thank you
Old Sep 22, 2020 | 07:22 AM
JayTheCPA's Avatar
JayTheCPA
Apologies in advance for not having information about the drive shaft.
Just curious, are you tracking that this swap might present a step-backward in terms of gearing? Unless I am missing something, OD gears are 0.71 for the 4R100 and 0.77 for the ZF-5 (am presuming it is the diesel s5-47 variant). And reverse is a little fast too as the S5-47 is 4.66.
Old Sep 22, 2020 | 07:31 AM
Hood_stackeez
I am switching to the zf5 simply due to preference. I have considered this but I am not too concerned and it is the s5-47.
Old Sep 22, 2020 | 08:37 AM
SkySkiJason's Avatar
SkySkiJason
I would also discourage this, but can try to answer your question.
If you are using the OBS/ZF5 t-case, you’ll need to have the front of driveshaft modified for the different style flange on T-case.
Ill have to go look at the 2 different t-cases to remember what else is different.
I dont know how the driveshaft lengths are different, but that will likely need to be addressed. To shorten a shaft usually costs me about $50 locally. If you need different ends, that can easily double the cost.
Not sure about crossmember differences either.
There are several other challenges that need to be overcome as well.
Old Sep 22, 2020 | 10:13 AM
Hood_stackeez
I appreciate the input. However I am working with a 2wd model so it is only the rear shaft. As well as the cross member can be moved forward and the mounting hardware from the 4r100 can be reused.
Maiden666
Oct 7, 2019 08:25 PM
Kj.keiscome
26
Jun 7, 2017 10:41 PM
