300 Head Bolt Torque
Old Sep 20, 2020 | 06:28 PM
Old Guy F-250's Avatar
Old Guy F-250
This is a easy one for some of you all.I have been checking on the inter web for correct torque for head bolts on a 73- 79
300.
interweb says 80 some say 85. I am familiar with the torque pattern. Most of my exp. has been on v8's.
Thank you in advance for your time.
Old Sep 20, 2020 | 07:11 PM
440 sixpack's Avatar
440 sixpack
It really doesn't matter just split the difference. unless you have a quality torque wrench that's been verified it's not within 5 lbs anyway chances are. I've seen them off 15 lbs that's why I bought a Snap On one and I verify it every year.
Old Sep 20, 2020 | 07:32 PM
dlburch's Avatar
dlburch
From the Ford engine shop manual...
Old Sep 20, 2020 | 09:13 PM
ford390gashog's Avatar
ford390gashog
300.
STEP 1: TORQUE IN SEQUENCE 55 FT/LBS
STEP 2: TORQUE IN SEQUENCE 65 FT/LBS
STEP 3: TORQUE IN SEQUENCE 85 FT/LBS
RECHECK FINAL TORQUE IN SEQUENCE
Old Sep 21, 2020 | 08:25 AM
Old Guy F-250
First, Thanks for the help.
440 Sixpack I guess my question was what is the torque specs actually, I was not sure if those numbers were correct, not the tolerances, I am searching for an old motor manual for this engine.
As for the torque wrench, the one I use was given to me by a retired engine builder that built engines for a living. so close enough for what I am doing. If I was building a racing engine then, definitely go with the certified wrench..
What I was looking for is what was supplied by DLburch and Gashog. EXactly what I was looking for.....
Just FYI, I just purchased this 79 4x4 flareside several weeks ago and doing a partial restore and was checking and cleaning under the hood, had valve cover off and thought I would check head bolts torque.
Thank you, I really appreciate all you spending your time helping.
rustyolred27
Apr 26, 2009 05:53 PM
TheRon
Bronco II
Sep 10, 2008 05:31 PM
fluidp
Jun 28, 2008 02:56 PM
