Cab mounts
Old Sep 17, 2020 | 08:13 PM
Philpalmer's Avatar
Philpalmer
Cab mounts
Hi I am new to the forum. I recently bought a 1966 Ford F 350 and need help finding cab mounts. I don't believe the ones for the F 100 will fit the F 350s. Also trying to find rear shock mounting brackets the truck doesnt have rear shocks.
Any help would really be appreciated.
Old Sep 18, 2020 | 09:51 AM
TA455HO's Avatar
TA455HO
Lead Gopher
These cab mounts?
https://carolina-classics.com/produc...mounts-1961-64
Or something else? Last time I pointed someone to these they said no, not those but the rubber mounts. Those are actually called insulators so it was just a terminology thing in that case.
Old Sep 18, 2020 | 09:57 AM
James_Western_Canada's Avatar
Phillip: First off, WELCOME!!
But to clarify, do you need cab mount Bushings/rubbers, or the structural part of the cab that rests on the frame mounts?
If you do a search, the cab mount rubbers for F350 & most 4WD's have been discussed numerous times.
If you need the actual mounts that are part of the cab structure, they're the same for all 1961-64 cabs F100 thru 350, and 1961 thru 1966 F400 thru 1100, and are also used on any of the 4WD cabs, The one EXCEPTION is 1966 F100 4WD, which uses the same cab mounts as the twin I beam cabs.
**The easiest way to distinguish is, if the cab has a step well when you open the door or not. Step well cabs use a different front cab mount than the twin I beam cabs, which do not have the step well.
whitey1371
Aug 23, 2016 03:20 PM
f100today
May 28, 2016 08:07 AM
z1121jack
Apr 5, 2010 04:36 PM
64shrtbed
Mar 6, 2008 01:26 PM
rayray2k22002
Sep 3, 2002 04:46 PM
