Sponsored by: Real Truck
Motor Mount Question
Old Sep 16, 2020 | 11:21 AM
BlackTruckDave's Avatar
BlackTruckDave
2008 F350 5.4l
I removed the passenger side exhaust manifold. 1 Stud came out and the rest snapped except for the bottom of #3. After a nitemare of a time getting the others out I found I couldn't get my stud extractor onto the only full stud left. I impatiently took a notch out the metal covering that is pressed onto the motor mount to fit my stud extractor onto the bottom stud of #3. In hindsight I should have put some heat on it and bent it.
I hope I didn't do too much damage. Another lesson. Any input is appreciated.
Thanks
Old Sep 17, 2020 | 11:21 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Next time, get a jack and unbolt the motor mount and lift the entire engine. I did it on my 2001 V10 doing the exhaust studs.
Can you post a picture of what you're talking about?
Old Sep 17, 2020 | 11:55 AM
BlackTruckDave
I know I screwed up. I probably need to get a new one and should do it before installing the new exhaust manifold.
Old Sep 17, 2020 | 12:43 PM
BlackTruckDave
I see I can get this part from $83 on up. Recommendations?
Now I just need the procedure. The aftermarket manual has a lot of things being undone to lift the motor but I have seen the posts and videos of jacking the motor to help in the manifold replacement. Is that high enough to get this out without undoing the transmission mount and D/S mounts? I have all the space there now since the manifold is out.
Old Sep 17, 2020 | 12:50 PM
BlackTruckDave
I believe this is what I need.
Can anyone confirm this is the only thing I need before I hit the buy button?
thanks
Old Sep 17, 2020 | 06:02 PM
krewat's Avatar
krewat
That looks like a heat shield... I don't remember seeing something like that on my '01...
I don't think it's structural...
Old Sep 17, 2020 | 07:26 PM
BlackTruckDave
Thanks,
That's what I thought also as I was full steam ahead at that last stud. That looks like a heat shield since the header it right here. Let me just notch this out and I'll put some of that heatshield tape over it.
I would like to get some more feed back before I start that manifold install.
Hate for it to be something to do with vibration and find out after damage occurs.
Old Sep 17, 2020 | 07:43 PM
krewat's Avatar
krewat
Before I quit for the night... if you're worried about vibration with a V10, you're driving the wrong vehicle - Just kidding... that looks like it shields the rubber in the mount.
Old Sep 17, 2020 | 08:38 PM
BlackTruckDave
i hope so. I want to just be done with this manifold
dobenator
Aug 9, 2020 05:13 PM
acolvin
Dec 8, 2019 05:09 PM
custom68
Feb 26, 2004 07:47 PM
