Offroad & 4x4
Tire chains
Old Oct 21, 2003 | 12:47 PM
Bowcop's Avatar
Bowcop
Tire chains
Please forgive me on this, it's been a while..................
If I only have 1 set of chains and need to chain up in 4 wheel drive, do I put the chains on the front or the rear?
Thanks all!
Old Oct 21, 2003 | 01:49 PM
ctfuzzy's Avatar
ctfuzzy
I vote for the rear.
. . . but I live in FLORIDA
Old Oct 22, 2003 | 03:09 AM
willd's Avatar
willd
All the weight is in the front. That's where I put mine. The rear won't do half the work with chains that the front will. Besides without chains on the front you don't stop or turn.
It's whole different story if you are loaded to the gills and the front tires have very little weight on them. Then you don't want them on the front because there is no weight for traction, but you won't stop or turn very well either.
Old Oct 22, 2003 | 09:57 AM
jimandmandy's Avatar
jimandmandy
Rear, because there is less weight there and the rear tires need more help. Does Washington require chains on 4x4's?
Jim
Old Oct 22, 2003 | 02:12 PM
Texan1983's Avatar
Texan1983
i have heard that with some mud tires and snow tires in states that requre chains you don't need them because of the tires. am i making this up?
oh yea i vote for rear, somehting about having them on front only makes me nervous, but i never use chains so i don't know.
Old Oct 22, 2003 | 03:43 PM
jimandmandy
Most chain restrictions in California exempt 4x4's with snow tires, but they do say to carry chains. FWD passenger cars with chains on the front are absolutely miserable to drive. The vibration is terrible.
Jim
Old Oct 23, 2003 | 08:18 PM
rebocardo's Avatar
rebocardo
Chains break, when they break in the front they are very likely to take out brake stuff, especially hoses. Aired down front tires can get a lot of traction, no so for rear tires. I would put them where they are needed most, in the rear.
Old Oct 24, 2003 | 12:32 AM
Bowcop's Avatar
Bowcop
Thanks to all of you for the info! I will be putting them on the rear if I need them.
Old Oct 24, 2003 | 11:43 AM
rrawlins's Avatar
rrawlins
Late vote here...Front. I've spent decades trolling around in the bush doing seismic exploration. Want proof as to which is best? Get into some good snow with a variety of terrain. Chain up the back and try and climb a small hill. Now put the chains on front and try the hill again. More proof? chain up the rear, put the truck into a set of tire ruts. Try and steer out of the ruts. Not gonna happen. Now put the chains on the front. More proof? Set up some hiway cones to make a slalom course. Put the chains on the back. Run the slalom course and time yourself. Now put the chains on the front and try again. NO comparison. Chains on the front are far superior to putting chains on the back!
Old Oct 24, 2003 | 01:15 PM
willd's Avatar
willd
Ditto again. I've spent many a day hauling stock trailers and heavy equipment trailers through snow and breaking drifts. Putting them on the front will usually get you almost as far as having them all the way around. As for vibration, you shouldn't be driving more than about 45 or so with heavy chains on unless you really need to.
