Truck lean after level
Old Sep 13, 2020 | 09:42 PM
stangDiesel's Avatar
stangDiesel
I got an issue. I installed a Fox 2.0 2.25 Coil over leveling kit with rear shocks about 3 weeks ago. Everything looked good, got it aligned and so on. Now, lately I noticed the rear passenger side of the truck lucks like it’s leaning to one side. And as a matter of fact, the front does too. Is this part of it adjusting and settling? Or can a rear shock failure do this? Only thing I changed was the rear shocks on the backside.
Old Sep 13, 2020 | 10:05 PM
JKBrad's Avatar
JKBrad
Did you make sure the fronts were both adjusted to the same height before installation? Once on the truck, the Fox 2.0s can not be adjusted, they need to be removed for adjustment.
Old Sep 13, 2020 | 10:07 PM
stangDiesel
I did not adjust them. I was under the impression that they came ready as is to install evenly. And can be adjusted lower after that.
Old Sep 13, 2020 | 10:39 PM
JKBrad's Avatar
JKBrad
They can’t be adjusted on the truck like some other coil overs out there.
Old Sep 13, 2020 | 10:44 PM
stangDiesel
Oh ok. I just thought that they did not need to adjusted out of the bountouched). Just plug and play.
Old Mar 6, 2024 | 09:13 PM
Ciscokid3000's Avatar
Ciscokid3000
2nd Gear
I have the same issue now! About a month ago, I installed the Fox 2.0 leveling kit with the rear shocks on a 2021 F-150 FX4. I noticed my rear leans almost 2 inches to the right now! And it's worse when I fill up my 36-gallon tank. Do you have any suggestions besides removing the coilovers and adjusting them 5/8" lower, as the Fox installation manual states? I worried it would not fix the issue. Has anyone had any issue with the Fox 2.0?
Old Mar 6, 2024 | 09:36 PM
JKBrad's Avatar
JKBrad
It’s amazing people buy Fox. So many issues with them.
Anyway, did the shop replace any blocks in the back? Are the rear shocks oriented properly? The skinny side should be down on each side.
Old Mar 7, 2024 | 09:02 AM
scott91370's Avatar
scott91370
It leans to the right but worse when you fill up? The gas tank is on the left side, why would it get worse?
dananash2000
Nov 8, 2018 10:32 AM
the cleaner
Modular V10 (6.8l)
Aug 7, 2014 06:59 AM
santi2322
Sep 1, 2010 01:00 PM
saltamontes
Mar 3, 2009 03:43 PM
MDFairchild
Dec 2, 2002 08:27 PM
