Volare question.
Old Sep 8, 2020 | 01:17 PM
raerjim's Avatar
raerjim
Volare question.
I was under the Volare equipped 55 this afternoon, looking for the cause of the 45-55 mph shaking steering wheel I am experiencing. Looking down the length of the right side torsion bar, I see a gap between the steel of the t-bar and the rubber of the mount of some 1/8" or maybe even a little more. I'm assuming there should be no gap.This is the mount closest to the end of the bar. I'm thinking I may have located my issue. Ireplaced the t-bar bushings that bolt to the control arm couple years ago so thats not my problem, and no broke or leaking shocks. TIA
Old Sep 8, 2020 | 03:11 PM
Steve Bennett's Avatar
Steve Bennett
I just went to the garage and looked under my truck. I don't see any gap between the torsion bar and the rubber. I'm assuming you only had this issue on 1 side? I believe you have located your problem as I have no vibration in the front end at any speed. Parts should be readily available to repair this. Good Luck, Steve
Old Sep 9, 2020 | 05:38 AM
raerjim's Avatar
raerjim
Thanks Steve. Gonna see about those bushings today.
F250MJ
Sep 15, 2021 07:45 PM
Robrt32
Sep 22, 2015 07:15 AM
wbnethery3
1997 - 2003 F150
Sep 30, 2012 08:58 AM
JOHN2001
17
May 31, 2012 07:41 PM
fordmudderone
Apr 9, 2008 09:23 AM
