Sponsored by: Real Truck
Please help no start
Old Sep 6, 2020 | 03:09 PM
Jason62371's Avatar
Jason62371
Exclamation Please help no start
Ok so I bought a 2002 ford f450 7.3 from a guy that said the motor just quit on him. I got it replaced the cam sensor. I got to messing with the scanner and it would not do a injector test.it gives codes p1293 p1294.my guess was the idm.i ordered one. I probably should of checked the wires with a meter but can not find much about this 450 online.can someone help with that? I know the signal goes from the pcm to the driver module then to the injectors. The wires looked good.i swapped relays around and same thing.all fuses are good.only thing I never checked was the relays under the hood in the tiny box.what ever they are. My guess is what ever is stopping the test is my problem. I don’t want to go broke swapping parts.
