master cylinder upgrade/update ?
Old Sep 5, 2020 | 10:24 AM
dustyroad's Avatar
dustyroad
Without moving to a hydroboost setup, is there anyway to update the master cylinder to one with the plastic cap?
I'm so over dealing with this metal lid/rubber gasket and brake fluid getting pushed out of the top.
I cleaned the lip off the master cylinder, replaced the gasket and it still wants to push brake fluid past the lid.
I do not have it over filled so that isn't the problem. It just isn't sealing and I'm over dealing with that pos baling wire.
Both my ford truck do this and I'm out of ideas besides getting c clamps and ratcheting that POS down tight
I did a search but all I found was posts about the hydroboost upgrade. Can you say frustrated?
Old Sep 5, 2020 | 11:21 AM
Franklin2's Avatar
Franklin2
There was a recent post about this. It was a little vague and unclear with nothing definitive if I remember correctly. I have never done the swap, but from memory of someone doing it long ago, the bolt pattern to the booster didn't match up exactly and require a little filing of the holes of the newer master cylinder to make it fit the studs. I get the impression it's very close, so not too much filing is required. And then the fittings on the lines won't match up, but you may be able to find adapters in the store to make that work. Keep researching.
Old Sep 5, 2020 | 11:45 AM
dustyroad's Avatar
dustyroad
I did recall reading that post, it was a bit vague. I'll look for that post again and re-read it.
Old Sep 5, 2020 | 04:59 PM
Ken Blythen's Avatar
Ken Blythen
I recently bought a rebuilt Cardone (never again ) power booster/master cyl unit & installed it.
Like yours, the lid immediately poured fluid out. After trying a couple of different gaskets I looked closer....it didn't have a machined surface for the gasket & lid to seal onto, just the cast face which also had a depression in one spot, it was never going to seal.
I stripped it down for machining & saw the rear face of the cylinder (that mates to the booster) was also just rough-cast; there was still pitting in the bore from the rebuild; & the aluminum piston also had corrosion pitting........I hurled it into the rubbish pile & ordered a brand new Raybestos unit which was perfect.
Your top surface might be the issue too
Old Sep 5, 2020 | 07:15 PM
Rembrant's Avatar
Rembrant
I'm running one of the 87-91 style master cylinders in my 1984 F150. It was a pretty straight forward install, but I was re-doing all of the brake lines at the same time.
The main reason I did the swap was to get rid of the rusty cast iron stock style master.
Details:
The front and rear brake ports are reversed from the stock master cylinder, so you will have to deal with that. (I was running new lines anyway, so NBD)
The rear residual pressure valve (attached to the master cylinder) does not come with a new master. I grabbed one at the Junkyard for $5 bucks (and a spare for another $5).
I removed the original Bullnose prop valve on the frame, and then connected the two wires to the float switch in the new master (so my brake warning light still functions). If you go to the junkyard to get a residual pressure valve, grab the float switch pigtail from the same truck.
Other than that, it works just fine. I've had it on there for a couple years now I think.
The piston is the same size as original, so braking power is the same.
The later master fits the Bullnose booster just fine. (Although I did adjust the push-rod tip a little bit)
Old Sep 5, 2020 | 08:41 PM
dustyroad's Avatar
dustyroad
Perfect thank you very much. Exactly why I want to replace mine and exactly what I was hoping for.
Good tip on the residual valve.
Old Sep 8, 2020 | 10:06 PM
BigBlue2's Avatar
BigBlue2
I'm on my 2nd or 3rd master cylinder and none of the reservoirs ever leaked. Go with motorcraft or other top replacement and that shouldn't be an issue. I like the bail because it's easy and no tools required. A shop rag through the bail does make opening and closing real easy.
Odisvan
Sep 24, 2018 06:01 PM
Calbo3
Nov 28, 2015 02:22 PM
fordinmudd
Apr 12, 2006 03:33 PM
ham4ever
Nov 9, 2004 02:15 PM
78f250
Apr 21, 2001 10:33 PM
