Looked at one local dealer and all they had was 3:73 automatic trucks, Also I wondered if an Auto V-10 Crew Cab longbed would be O.K if It had The higher gears?
Be careful with the total combined weight rating. My supercab shortbed is lighter than a crew-cab, so it's tow rating is HIGHER than a crew-cab, and with 3.73, I'm limited to around 10,500 lbs. If it had a 4.30, it would go up to 12,500lbs.
Not entirely sure, but most people here do not seem to get a different MPG with the 3.73 vs. 4.30
For me, with the 3.73's, I wouldn't tow anything near the 10,500. It definitely needs the 4.30's. Otherwise, as an empty daily beater, the 3.73's work for me, and I get better than 16MPG on the highway doing 75MPH.
Aerodynamics accounted for some of the difference, as does weight, but the gearing of the '00 truck runs much higher rpm's on the highway - and as nice as that is for towing, it blows the mpg down in the process.
I have a '99 LWB 2WD Extended Cab w/V10. I bought the truck with 3.73's and drove it that way for 40,000 miles. I towed first a 7500 lb. travel trailer, then later a 10,000 lb. fifth wheel. After towing the larger trailer around for a year, I had the gears changed to 4.30's and have been very pleased. My unloaded milage dropped by only 1/2 mpg, while my towing milage increased by about that much. The trailer tows much better with the 4.30's. It runs much stronger at the higher rpm, staying in OD most of the time.
I'd say that if you are planning to tow that 11,000 lb trailer in hilly country, or if it has a high profile like a 5th wheel, you'll be frustrated with the 3.73's. If it's flat ground and a lower profile trailer, maybe you'll be happy.
Originally posted by mptjelgin I'd say that if you are planning to tow that 11,000 lb trailer in hilly country, or if it has a high profile like a 5th wheel, you'll be frustrated with the 3.73's.
Odd... If *I* were pulling 10k+ on a regular basis for considerable ditances, the V10 would be sold and a PSD would replace it
