Change oil warning
Old Aug 30, 2020 | 07:04 PM
Faceplant409's Avatar
Faceplant409
Change oil warning
What triggers the change oil warning?
I’m really late, but it’s getting done Tue.
Old Aug 30, 2020 | 07:21 PM
C12H24's Avatar
C12H24
Time (max one year from reset), distance, engine operating conditions. If the light isn't on, chances are you are not late. Follow the guidance in your owner's manual. You can always change ahead of the factory recommendations if it helps you sleep at night.
Old Aug 30, 2020 | 07:34 PM
Faceplant409
I am late according to my service guy. I think I’m going on 5000 mi. The light has come on every startup today.
is the viscosity monitored? Or is there a sensor that monitor oil level in pan?
Old Aug 30, 2020 | 08:07 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
The truck just uses a basic algorithm. There are no sensors to measure fill level or quality.
The algorithm is a formulation of time, miles traveled, engine hours, and engine load/temps over that period. It's basically just a more sophisticated dummy light.
I stick to a mileage number and just reset the message whenever it pops up
Old Aug 30, 2020 | 08:10 PM
Rich53's Avatar
Rich53
Usually the oil change monitors are based on fuel burn, that picks up operating conditions, the harder you work the truck, the more fuel you burn.
Old Aug 31, 2020 | 06:02 AM
Pugga's Avatar
Pugga
If you've only gone 5,000 miles, chances are they didn't reset the light during the last oil change. 5k miles between changes is plenty soon enough assuming you're putting on 10-20k miles a year.
nomad_archer
May 9, 2020 08:29 PM
Brian Fentress
Modular V10 (6.8l)
Apr 24, 2016 09:34 AM
CollinsCD
Aug 19, 2015 09:17 AM
KPT
6.7L Power Stroke Diesel
Jun 13, 2013 07:27 AM
red06
Alberta Chapter
Aug 29, 2012 12:15 PM
