460 swap
Old Oct 20, 2003 | 09:41 PM
ant 78's Avatar
ant 78
460 swap
can anybody tell me what's involved in swapping a 400 for a 460 in a 78 250 4/4 4 speed?
Old Oct 21, 2003 | 02:47 PM
rmcgraw351's Avatar
rmcgraw351
pull the 400 out and bolt the 460 in! no modifications
Old Oct 21, 2003 | 03:12 PM
MuchToMyDelight's Avatar
MuchToMyDelight
You might want to opt for some heavier springs up front if your old ones are sagging a bit. I am not sure of the weight differences, but I would say 200+ lbs at least. I know the tranny will bolt up, but I dont know about the engine mounts. A buddy of mine swapped a 351 M for a 460 and had to get new mounts. Im sure someone will know.
Old Oct 21, 2003 | 11:47 PM
460 Crew's Avatar
460 Crew
You need to get new mounts I suggest LandLproducts but perches stay the same.
Old Oct 22, 2003 | 01:22 AM
BB's Avatar
BB
Hi ant 78 and welcome to
Hang on, we're gonna take a little ride to the newer forum just above us.
Enjoy the site!
Barry
Old Oct 22, 2003 | 03:10 AM
willowbilly3's Avatar
willowbilly3
Don't forget you will need all the exhaust manifolds for a 460 pickup and the accessory brackets ect. I had a customer once with the exact swap done and the power steering pump would hit the steering box when the belt was tightened. I remember using the diegrinder quite a bit to remedy the situation but I don't remember the specifics
Old Oct 22, 2003 | 07:19 AM
b9inger's Avatar
b9inger
The difference in weight between the 400 and the 460 is 90 lbs. The weight of the 460 stock intake manifold and stock exhaust manifolds together is 91 pounds. If you plan on using headers and an aftermarket aluminum intake, you can probably figure on reducing that weight difference of 90 lbs to about half.
Old Oct 22, 2003 | 07:59 AM
neverenough's Avatar
neverenough
Do a search. For a manual tranny, it is a little more complicated than what has been posted, but it has been talked about many times here. Good luck.
Old Oct 22, 2003 | 08:00 AM
grapegravy's Avatar
grapegravy
Go to the 460 forum, it's been discussed there ad nauseum. All 460 swaps
