Get double batteries ...
Old Aug 28, 2020 | 06:42 PM
RenoHuskerDu's Avatar
RenoHuskerDu
If you're spec'ing a dump trailer, be sure to spring extra for double batteries. It's money well spent. I've been transporting and dumping 50+ tons a day, and my hydraulic dump has not slowed down one bit. The fact that my pickup is newer might help, with thicker wiring back to the 12v in the socket.
Previous to buying a dump, I rented them. Single batteries, even brand new, start to slow down seriously after 4 dumps. I ran a 110v cord from inside the cab back to the trailer's charger. That helped some.
Old Aug 29, 2020 | 08:17 AM
HRTKD's Avatar
HRTKD
The newer Super Duty trucks don't put out many amps to the 7-pin connector. You might see 15 to 20 amps.
Old Aug 29, 2020 | 08:59 AM
RenoHuskerDu
Not surprising, Furd is cheaping out more and more these days.
What would a gen1 SD see in amps back there? I have an 04 but don't tow heavy with it. The 6.0 isn't up to the task.
I have an E99 F550 4x4 200' wb that I'm building out to be my primary tow rig for quarry trips. I plan to wire its trailer plug with 10 gauge.
Old Aug 29, 2020 | 09:32 AM
HRTKD's Avatar
HRTKD
I can't help with the amps for an older truck.
Running a dedicated wire of sufficient gauge is the way to go. 10 gauge wire is not stout enough. A DC-DC charger may be necessary to limit the number of amps that get pushed to the trailer.
Old Aug 29, 2020 | 05:20 PM
RenoHuskerDu
Well it was a elec/hydr boom truck in its former life, and I saved all that cable when I removed the bed. Maybe I'll wire it up with 00 gauge back there, lol.
Old Sep 27, 2020 | 12:29 AM
nikerret's Avatar
nikerret
I did this:
https://www.ford-trucks.com/forums/1...for-power.html
Old Sep 29, 2020 | 08:24 PM
RenoHuskerDu
Originally Posted by nikerret
That's sweet, and could also run a winch on your car hauler.
Old Sep 30, 2020 | 08:57 PM
nikerret's Avatar
nikerret
Yeah, the amount of uses is limited only by imagination and the OE alternator jamming through 2 AWG.
chi6488
6.4L Power Stroke Diesel
Jan 8, 2011 01:26 PM
messeswithtrux
27
Nov 13, 2008 09:05 PM
73cntry
15
Sep 15, 2008 02:33 PM
MARTYSTOWRIG
All Things Towing
Jan 14, 2008 02:02 AM
PSNut
Electrical Systems/Wiring
Feb 27, 2006 01:15 AM
