Timing off
Old Oct 20, 2003 | 09:31 PM
opporll's Avatar
opporll
Timing off
My 94 F150 4.9L just started making a noise like its timing was too far advanced and the fuel milage has been lousy. So when I go to time it the mark isnt showing up any where I can see. I put white out on the flywheel notch and disconected the spout conector, still it wont show up in the light. Any suggestions
Old Oct 20, 2003 | 10:43 PM
yellowjeep76's Avatar
yellowjeep76
it is possible that the outer ring of the harmonic ballancer has moved. it has been known to happen on the 4.9. also, sometimes the harmonic ballancer has more than one notch.
Old Oct 21, 2003 | 07:09 PM
1987LTDmasta's Avatar
1987LTDmasta
thats exactly what happend to mine, and it was giving me all sorts of problems, from engine dying at stoplights, to very slow cranking.
you just have to time it the old fashioned way. remove the 1st spark plug, then move the crank till the piston is at the very top of that cylinder. a long straw can assist in this. once its at the very top, then mark the outer ring at 0* and time it from there.
Old Oct 21, 2003 | 10:39 PM
rikfish's Avatar
rikfish
If I remember correctly, there are TWO marks on the balancer. You might take a look to see if you marked the wrong one.
Old Oct 22, 2003 | 09:03 PM
opporll's Avatar
opporll
There only seems to be one mark. but thanks for reminding me about the "old fashion way" I completly forgot about it. sounds like when i bought it now
Old Oct 23, 2003 | 12:01 PM
StrangeRanger's Avatar
StrangeRanger
The notch is NOT the timing mark. There are 2 timing marks, one at 0 and the other at 10°BTDC. You may have to crwl under the truck to see them on the pulley. Once you find them, mark them with paint. The timing indicator is not yhe numbered sector cast into the timing gear cover, that is a vestige of much earlier trucks. he timing indicator you want is located on the front of the engine right next to the pulley at about 9 o'clock. Remember to pull the SPOUT connector before setting the timing.
