Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Coolant
Old Aug 26, 2020 | 12:34 PM
Jay Wells's Avatar
Jay Wells
Coolant
I've been chasing an overheating problem. Does anyone know what the coolant capacity is on an 89 ford C-8000 with a 3208?
Old Aug 26, 2020 | 12:53 PM
ford390gashog's Avatar
ford390gashog
Its right at 13 gallons if I remember right. Also if you replace the thermostats ( Yes there is two) to only use the original parts from CAT or reliance. There is some junk disc thermostats made by stant for this engine and are totally trash.
Old Aug 26, 2020 | 02:10 PM
Jay Wells's Avatar
Jay Wells
I pulled the radiator and the hoses and only got about 5 gallons out. Is that normal? I would have thought all the coolant would have come out.
Old Aug 27, 2020 | 04:43 PM
Destroked 450's Avatar
Destroked 450
Quite a bit stays in the block but you should have got more than that out, we drained the radiator on a L model and got around 8 gallons
Old Aug 29, 2020 | 10:15 AM
F350 1990's Avatar
F350 1990
Good engine, plenty still out there, running, working even though they stopped production decades ago, not sure which variant you have:
http://www.catengine.info/workshop/3...ng-system.html
3208 is known for a problem with coolant crossover tubes / passages (steel or plastic) ---> hardened / failing / failed o-rings
(very common and a typical replacement item)
If yours are plastic you'll likely have to pull heads on the beast to replace, plus front components (engines are heavier than most-- around 2,000 lbs)
Another key check if cooling is a problem:
http://www.catengine.info/workshop/3...ure-check.html
And of course the radiator cap seal (very common problem):
http://www.catengine.info/workshop/3...ssure-cap.html
dustin hill
Jul 9, 2020 12:04 PM
Anthony Giovino
Ford Truck Parts for Sale
Apr 15, 2017 07:55 AM
fski50
6.7L Power Stroke Diesel
Apr 26, 2015 08:28 PM
A/Ox4
Apr 3, 2013 07:14 PM
TXBDBY
Nov 24, 2006 06:15 PM
