need help
Old Aug 25, 2020 | 11:55 AM
jdbartlett's Avatar
jdbartlett
need help
So I have an old 1978 F150 with a 1985 f150 306 and I was wondering if anyone would know of a reliable website that would have thermostat housings?
Old Aug 25, 2020 | 12:24 PM
HoustonDave's Avatar
HoustonDave
Assuming you mean 300-6 and not 306, you can try
Amazon Amazon
Be real careful that the thermostat and gasket are correctly in the housing, if the edge of the thermostat slips in between the housing and block you will likely stress and crack the housing. Dummy mistake number 4,463,859 I have previously committed.
Old Aug 25, 2020 | 04:10 PM
1TonBasecamp's Avatar
1TonBasecamp
And if it's just a bored out 302, then this may work: https://www.wildhorses4x4.com/produc...co_Water_Pumps
It's our site, so pardon the shameless plug, but we've carried them for a long time and I happen to know they're there!
This is the standard old style, vs the more vertical outlet of the newer 5.0 EFI type. But should be correct for your truck with a 302 based engine.
It's the stock aluminum (not chrome like the latest pic looks) with a threaded boss at the top for a temp sensor/fan controller or whatever.
If you have the Inline-6 engine, not sure what you'd need.
Is yours all corroded to death? Or have some other issue?
Good luck.
Paul
babymonster9
Crossovers
Dec 26, 2010 07:52 PM
Fordtruckgrl1369
2004 - 2008 F150
Nov 29, 2008 09:04 PM
