Replacing AC Compressor - How Hard and Best Source
Old Jan 18, 2021 | 03:31 PM
ztodd377's Avatar
ztodd377
Murray and other brands part number 38639 is the ‘colder AC’ orifice tube. I’ve put this in literally dozens of these trucks.
It’s also commonly ‘orange’. I’ve used other brands that have the same orifice size (0.057”) and they were also orange.
https://www.ackits.com/index.php?rou...earch=31-50005
https://www.oreillyauto.com/detail/b.../4517996?pos=2
Still looking at options. Definitely going to go with the 38639 orifice tube. Is there any reason to stick with a Motorcraft compressor, or are the kits on Amazon and the like just fine. I'd like something that is going to last me at least another 10+ years.
Old Jan 18, 2021 | 03:38 PM
ztodd377's Avatar
ztodd377
SSJ,
Is the Motorcraft YG-343 the same as the Murray 38639? I found one on Amazon.
Old Jan 18, 2021 | 05:02 PM
SkySkiJason's Avatar
SkySkiJason
Originally Posted by ztodd377
SSJ,
Can you find an orifice size for that?
They are only a few $$ each at the auto parts store.
Old Jan 18, 2021 | 07:58 PM
ztodd377's Avatar
ztodd377
Think I'm going with the same kit FTN got from Amazon. Going to also a new evaporator. As a bonus, on my way home this afternoon my high pressure power steering line blew and puked ATF everywhere so I ordered a new one of those and a new power steering pump from Clay since the originals have over 240k on them.
Old Feb 20, 2021 | 09:20 PM
ztodd377's Avatar
ztodd377
I have the kit that FTN bought but the front of the compressor looks different than original. Not sure if it matters or not.
FTN, did your compressor pre-oiled, or did you have to add the 7oz yourself?
Old Feb 20, 2021 | 09:37 PM
FordTruckNoob's Avatar
FordTruckNoob
That’s just a different clutch. I had to add oil to the system myself. I don’t recall what the correct amount is at the moment. I replaced everything though so there was no residual oil.
EDIT: Our AC system takes 42oz of R134a refrigerant and 9oz of PAG 46 oil per this chart.
Old Feb 22, 2021 | 09:41 AM
ztodd377's Avatar
ztodd377
Got everything installed yesterday. Went pretty smoothly except for the line that connects from the condenser to the evaporator. I used the special release tool to separate the line, put in the new orifice, new o-rings, and new spring piece but can’t for the life of me get that to go back together.
The other issue I have is that my 20 year old heater core hoses finally gave up the ghost so I’ll be replacing those shortly. I’ve used the Ranger valve mod for the A/C previously and am wondering if I’ll still need it with the new SSJ recommended orifice.
Old Feb 22, 2021 | 11:06 AM
ztodd377's Avatar
ztodd377
Has anyone tried the heater control valve from the 04-05 Excursions on our trucks? Heater Control Valve
Old Feb 23, 2021 | 06:39 AM
SkySkiJason
I just use a 3/4” PEX barbed valve on the heater core supply. Close it late spring and open it in the fall. Costs about $10 and leaks/failures unlikely. (Unlike the other options...)
Old Feb 23, 2021 | 06:41 AM
SkySkiJason
The quick connect fittings at the heater core often fail. I also delete these and just put hose clamps at the heater core. Not sure I’ve actually seen a hose failure.
Old Feb 23, 2021 | 07:18 AM
FordTruckNoob
I used one of these because it still allows circulation in that circuit while the heater core is bypassed.
Old Feb 23, 2021 | 07:23 AM
SkySkiJason
What is the reason for ‘circulation in that circuit’?
Old Feb 23, 2021 | 07:30 AM
  #28
FordTruckNoob
I don't like liquid that is supposed to be circulating as part of a larger system stagnating in a dead end. The stuff in the heater core is still doing that admittedly but at least it's a smaller volume.
Old Feb 23, 2021 | 09:54 AM
  #29
ztodd377's Avatar
ztodd377
I will probably go the ball valve route. My ranger valve always a slight leak.
Old Feb 23, 2021 | 11:48 AM
  #30
SkySkiJason
I think some ‘fresh’ coolant will migrate to each side of the closed ball valve - but I don’t think it matters. I’ve put the ball valve on lots of trucks and no issues (including leaks).
