What primer??
Old Aug 24, 2020 | 09:04 PM
J ballan's Avatar
J ballan
What primer??
Good day everyone, I’m in the process of restoring a 1970 F350 and I’m almost ready for primer. Welded in new floor pans, cab corners etc. Body filler is almost done. What is the best primer to use for a gloss black top coat. Doesn’t have to be show car quality just decent. Thanks
Old Aug 25, 2020 | 12:44 PM
Beechkid's Avatar
Beechkid
Todays paints are literally a chemistry class (or experiment) and it is best IMHO to stick with one mfg's product line for the primers, etc..
Old Aug 25, 2020 | 01:06 PM
J ballan's Avatar
J ballan
Thanks for the help. Any brand recommendations?
Old Aug 25, 2020 | 02:32 PM
ford390gashog's Avatar
ford390gashog
Well a 2k primer is what is common but you better make sure your body filler is blocked and pinhole free with no off gassing as is common with some fillers.
Old Aug 25, 2020 | 03:47 PM
Beechkid's Avatar
Beechkid
PPG, Sherwin-Williams, GE are all very good brands with different lines/grades ranging from basic (so to speak) to very high end ($$$). IMHO, whatever your local autopaint supplier sells, that's what I would go with because they will know that specific line very well, understand which specific reducer/hardner to use (this is weather dependent) and you will end up with very nice results!
Old Aug 25, 2020 | 09:18 PM
J ballan's Avatar
J ballan
I’ll get in touch with my local auto body shop. Thanks
Old Aug 26, 2020 | 10:41 AM
Beechkid's Avatar
Beechkid
FYI- What you want is the auto body paint supply shop...... they will be not far away.
SeaCarr
Jan 5, 2017 09:56 PM
71mach351
Aug 21, 2011 07:08 PM
cts1954
13
Mar 3, 2008 07:01 PM
racoonbandit
Dec 30, 2005 03:25 PM
racoonbandit
Paint & Bodywork
Dec 30, 2005 04:50 AM
