1978 - 1996 Big Bronco
Engine or transmission first?
Old Oct 20, 2003 | 07:43 PM
Crownman's Avatar
Crownman
Hey all,
Im thinking of buying a 1986 ford full size bronco. It would cost me about 1500us the body is in great shape, with some rust but nothing extensive. Even the tails gate is in good shape, just a few small spots on the doors. The vechile has 195000 miles on it so im thinking it would be good to rebuild both the engine and transmission. I dont have the money to do it in one shot though.
What would be the best order to do this in?
Engine first, then tranny?
Tranny first then engine?
thanks for all your input
Old Oct 20, 2003 | 09:24 PM
screwy's Avatar
screwy
Do any have any particular problems? If your really set on rebuilding them I would do the engine first, but thats me.
Old Oct 21, 2003 | 10:14 AM
Kemicalburns's Avatar
Kemicalburns
it depends how does it drive now. is the motor smoking, knocking using oil. if not then i would drive it . same thing goes for the tranny, if they have been taken care of they should be fine until you can save enough to do both at the same time . if you dont want to do that rebuild the tranny first. otherwise if you do the motor first it will probably cause fallure to your tranny because of the new power your putting threw it. but doing the tranny first it would help the motor thats in there last a bit longer.
sorry bout the ramblin
late
Old Oct 21, 2003 | 12:55 PM
Crownman's Avatar
Crownman
Yeah both seem to be running decent, that was what i was thinking, if I rebuilt the motor the tranny might not be able to take it. Neither is that bad but both componenets are very "tired" I want to have a good reliable runner.
Old Oct 21, 2003 | 09:33 PM
3broncocrazy's Avatar
3broncocrazy
IMO - If both are running decent, keep running it. Save your $ and do both at the same time or replace the first to fail and keep your foot out of it 'till you can replace the other..........Then again, might get a better deal than the 1500 if you talk it down more to the sailer, i mean seller - Go forward and charter new water, only in a bronco
Michaelj615
Bronco II
Dec 29, 2018 08:12 PM
Gary Lewis
5532
Jul 9, 2017 09:20 AM
Michaelj615
Nov 11, 2016 11:17 PM
Timwolve
Jan 23, 2014 11:05 AM
dougvidak
Bronco II
Aug 13, 2004 04:14 PM
