Oil pans
Old Aug 24, 2020 | 10:58 AM
bcave's Avatar
bcave
Oil pans
doing a 55 f 100 build on a 2004 crown vic interceptor frame with a 1998 5.0 from truck does anyone know if I will need a different pan and will the motor mount bolt right to motor or will I need a conversion plate
Old Aug 28, 2020 | 06:00 PM
baddad457's Avatar
baddad457
You're in uncharted territory here. That year Vic never had a small block Ford in it.
Old Aug 28, 2020 | 07:29 PM
diggerrigger's Avatar
diggerrigger
I thought that only Explorers and Mountaineers had 5.0L engines by 1998. An F series truck would have had a 4.6 or a 5.4 modular engine.
The Crown Vic was an early adopter of the 4.6L in the early 90s. Did the frame of a Crown Vic change much, if at all between then and 2004? The body never changed much. The classic small block 5.0L in an even earlier CV had a double sump pan. The same pan as a Mustang I believe. The front sump was needed to house the oil pump. The later modular engine needed no such accommodation as the oil pumps are completely different.
If the 1998 5.0L engine in question is not from a truck but from the Explorer or Mountaineer then yes, who knows? If the engine is a modular from a 1998 truck then any CV pan from say 1993 on should fit this application.
old_lynrd
Dec 24, 2010 04:11 PM
Saber123316
Jan 27, 2009 08:26 PM
Cybertaz126
Aug 1, 2006 04:23 PM
ymurf
18
Feb 29, 2004 04:10 AM
stangbitten
Jul 19, 2000 05:38 PM
