F150 Running board brackets?
Old Aug 20, 2020 | 05:56 PM
jwduke's Avatar
jwduke
I'm looking for the F150 running board brackets to raise the running boards on my F250.
What years of F150 brackets fit my truck?
I see a lot on Ebay for 2011 to '15 trucks. Will these work?
Thanks in advance!
Old Aug 20, 2020 | 09:49 PM
ford390gashog's Avatar
ford390gashog
The brackets you want are for a 2015+ F150.
Old Aug 21, 2020 | 07:35 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
2015+ F150 and 2017+ SuperDuty share the same cabs (minus a couple tweaks on the firewall).
Most things F150 will swap with the SD if it is interior or cab related. I have F150 running boards, steering wheel and center console in my SD.
Old Aug 21, 2020 | 08:10 AM
Beast2.0's Avatar
Beast2.0
Super Duty cabs are also screwed together at the roof panel in addition to glue. If you compare a 150 to a SD, you will notice the SD's have that black trim piece on each side of the roof, 150's do not. I found this out the other day when installing Thule roof rack on my CC 350. Must be to make it stronger?
Old Aug 22, 2020 | 11:15 AM
jwduke's Avatar
jwduke
Thanks for the information! I'm just looking for the brackets, seem to find a lot of them on ebay, that are 2014 and older. Didn't want to buy something that wouldn't work.
Old Aug 22, 2020 | 01:03 PM
fordman19762003's Avatar
fordman19762003
If you are reusing your SD boards remember to get six F150 brackets. The F150 boards only come with two brackets per side.
ETA. I put a set of takeoff F150 boards on my SD and I'm getting along just fine with only two brackets per side. There is a little flex in the center but not bad.
reesestewww
Aug 20, 2022 08:52 AM
Glocklover72
Jul 30, 2020 05:06 PM
RedRage
2015 - 2020 F150
Apr 26, 2020 09:36 AM
Pitguy3
May 7, 2019 11:14 PM
Jersey Sierra
May 17, 2018 07:18 PM
