Clutch or not
Old Aug 20, 2020 | 02:37 PM
gmcalis's Avatar
gmcalis
Clutch or not
How do you know when the clutch is bad or its just the operator? Im 99.9 percent sure its me, just started driving the ‘50 F3 with 4 speed spur nonsychnized.
But, it grinds going into 2nd when dead stopped. And shakes like a washing machine starting off in 2nd and reverse.
Im new to this tranny which I know is a different beast but I have plenty of experience driving other manuals.
Old Aug 20, 2020 | 03:42 PM
Steve's Avatar
Steve
At hot idle, with the trans warm, the gears should spin down slow enough to engage without grinding after 2-3 seconds upon disengagement of the clutch. When cold, it should be pretty much immediate. The diagnostic question would be, at what point in the pedal travel does the clutch engage? If it's near the floor, then it could be dragging, causing your issue. A sticky pilot bearing can do this also. As far as the shudder goes, if it's an old clutch, the facings could have oil on them or the pressure plate and/or flywheel are heat checked/polished. Might be time to pull it apart to inspect.
Old Aug 20, 2020 | 05:19 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Make sure the free travel is set right if there is no adjustment left the clutch may be done
You can double clutch it and if the clutch is working that will fix your grinding issue, as long as you do it right.
Old Aug 20, 2020 | 05:30 PM
1956_F100's Avatar
1956_F100
Worn damper springs in the clutch disk, worn pilot bearing allowing the input shaft to wobble, are just a couple of other things that will also cause chattering when slowly engaging the clutch.
Old Aug 20, 2020 | 05:31 PM
Bob Ingram's Avatar
Bob Ingram
I’m just learning to drive a spur gear as well. As a comparison, mine takes a second or two to be ready to hit second gear after hitting the clutch. If I’m too quick, it will grind, but if I’m patient, it will just vibrate a bit on the way into gear, the clutch gives a little shake when starting up, but nothing I’m concerned about.
i think it’s a learning process. Back in the day a good driver knew how to negotiate a spur gear tranny, and a bad driver crashed gears.
Old Aug 20, 2020 | 05:36 PM
truckeemtnfords
The secret on tranny's like that is "Slow is Pro". Shift like a sports car and it will grind every time.
Old Aug 20, 2020 | 05:43 PM
Steve's Avatar
Steve
At what point in the clutch pedal travel does the clutch begin to engage? This is an important question to answer if we are to narrow down the possibilities.
In your original post it would "shake like a washing machine". Now it's a "little shake". Which is it?
Old Aug 20, 2020 | 06:06 PM
gmcalis's Avatar
gmcalis
[QUOTE=Steve;19441860]At what point in the clutch pedal travel does the clutch begin to engage? This is an important question to answer if we are to narrow down the possibilities.
In your original post it would "shake like a washing machine". Now it's a "little shake". Which is it?[/QUOTE
That was Bob that said his was a “little shake”. Not I.
Gabe
Old Aug 20, 2020 | 06:22 PM
Steve's Avatar
Steve
Heh. Right.
Where does your's engage though?
Old Aug 21, 2020 | 02:18 PM
gmcalis's Avatar
gmcalis
When releasing the clutch the gear engages about 2” from the top of the pedal travel.
Old Aug 21, 2020 | 02:45 PM
wellcraft17's Avatar
wellcraft17
What weight oil are you using, something that old I would probably fill it up with 140w gl-1
Old Aug 21, 2020 | 03:11 PM
Steve's Avatar
Steve
Sounds about right to allow full release of the clutch. As mentioned above is the trans full of the correct oil?
One test would be to gently push the shifter (at idle) so the 2nd gear is just making contact with the cluster. Gently- so you can just feel it through the shifter.
Then push the clutch pedal to the floor and get a feel for how clean the disengagement is by how long it takes to spin down.
Clutch shudder is super annoying. If you ever do tear it dwn, investigate the possibiliy of usinng a diaphragm style pressure plate as opposed to the 3-finger style. The diaphragm covers work so much better. A custom built one if it were to come to that is worth it in my opinion.
The shudder could also be loose or worn engine or trans mounts too- pretty easy to check that.
Old Aug 21, 2020 | 07:08 PM
gmcalis's Avatar
gmcalis
I know downshifting requires matching engine and tranny rpms.
i think Im not reving the engine RPMs high enough. Does it require quite a high rev?
Thank everyone for the info. I will check transmission oil tomorrow.
Old Aug 21, 2020 | 08:16 PM
1956_F100's Avatar
1956_F100
If you are considering a trans oil change, Lucas Oil make an excellent gear oil for non-synchronized heavy duty transmissions. They also have an oil stabilizer that works well. https://lucasoil.com/products/gear-oil
Old Aug 21, 2020 | 08:41 PM
Bob Ingram's Avatar
Bob Ingram
it depends on speed, but I find it takes very little, just a touch on the gas. The key is to anticipate the RPM the engine will be at after the shift, and match that.
