95 trans drain plug?
Old Oct 20, 2003 | 05:18 PM
F0rdF0rever's Avatar
F0rdF0rever
Does anyone know where the drain is on my 95 350 trans. The only one i can find was on the side of the transfer case.
Old Oct 20, 2003 | 06:57 PM
mrcobra350's Avatar
mrcobra350
If its an automatic it wont have one. You drain it by removing the pan. There is a drain for the torque converter pull rubber plug in bottom of bell housing and turn it over till you see the plug. Manual trans it should be on the bottom of the main housing.
