Just wondering if a 1949 to 52 cab can replace a 1953 cab and still bolt up with no issues? Have a 1953 cab that needs a lot more work than a 1952 cab that is available, but needing to know if changing just the cab for an earlier one is possible, thanks in advance.
Ok thank you, yeah was hoping I would get lucky the truck we have someone picked up with forks through the doors and creased the roof and top of the doors so finding a 52’ cab for 750 would have saved a lot of time and $$ if it worked.
As reported, 48-52 is totally different. 53-55 is the same, and 56 would work if you found one. The 53-55 should be at least, if not moreso, readily available as the earlier trucks.They're highly popular and Ford made a ton of them. Texas is a good place to look, too. Good luck with your quest.
And then how many have those cabs on late frames? = quite a few have done it. I am
about to do the same. A 1954 F900 cab is a little beyond for my old bones so its going
to get a 49 - 50 cab which is good that I have along with F8 fenders and running boards.
