What makes the 2020 F450 capable of towing 37,000 pounds?
Somebody, anybody show me a law that says that Ford, Ram, etc ratings are legal.
What is legal, you do not exceed tire capacity, axle capacities on truck or trailer.
Manufacturers don't have the legal right to dictate to you.....what's next.....
They can tell you what color your trailer can be or what aftermarket toys you add or play with (excluding tuners of course because those violate the clean air act)
I'm often over the rated GCWR, I have never seen a officer pull out a book and look up truck capacity..... never ever.
The ratings are based on a test that The manufacturers are agreed upon....... It's all about marketing playing and simple.
SAE J2807 Tow Tests - The Standard
And actually, the max you can register a 450 for would be 26,000 lbs and that is because 26,001 would require CDL. Nobody is gonna get a CDL to drive a 450 because that is insane
If your greater than your GCVWR and you get into an accident, your automatically at fault with your insurance if they put 2+2 together
Your insurance agent will probably pay the claim and drop you like a hot mic.
J2807 is the SAE standard that determines the tow rating of a truck. What earns you a ticket is an entirely different matter between you and the nice highway patrol officer.
I'm also the ELD administrator, for our company, DOT trained, and a Class A holder. Every two years, we go thru a insurance audit. We deal with facts, not assumptions.
Not in every state. In Texas, at least, a trailer over 12000 with a DRW f350 or F450 requires an exempt class A which is *not* a CDL. You can’t register the truck for over 14000– you’re likely not getting an overweight ticket without a CDL anyway. (But maybe! The law is murky and I’m not sure any one really understands).
It simple, show us a law saying manufacturers set the legal limit?
Give Google a work out.
The FMCSA is the sets the rules, states enforces them.
Think about it, how many light duty trucks/SUV's/Cross overs are out on the road, in various configurations, do you think DOT is going to carry around a manufacturers recommendations of GCWR for each model, and then break it down by engine, transmission, gear ratio....hell no.
And I won't even bring up grandpa and 1996 Crown Victoria pulling a trailer.
Single vehicle with a GVWR of less than 26,001 pounds towing a farm trailer with a GVWR that does not exceed 20,000 pounds
https://www.dps.texas.gov/DriverLicense/dlClasses.htm
I won't even pretend to know anything about farm life..... LoL
isn't there a mileage limit set?
As mentioned in other threads, my regular ride is a 550 and a 45ft GN triple axle with tandems with a avg gross of 45K. Truck is rated at 18K, trailer is 37,500 for a GCW of 55,500. If using my other 550's, add 1500 more.
If you look at the j2807 towing test, it's just so they rate trucks on a level playing field. most class 8 trucks cant pass that test and roll all day at 80,000.
what matters is axle ratings and hitch ratings to DOT who regulates it.
If truck is 16k and trailer is 20k, combo is 36k if hitch is rated for that weight.
if above example hitch is only rated for 30k gcwr, then 30k is max weight.
if you look at manufacturers towing test they care about acceleration, DOT not so much, otherwise a gas and diesel truck would have the same rating since axles and brakes are the same between chassis.
so if your hitch is rated 37k and you have axles (with the brakes as well) rated up to that, you can weigh that much.
#28
You can do basically whatever the heck you want with farm tags in TX, lol. I got rear ended in a 96 F350 DRW with close to 30000 lbs of hay on a gooseneck and nobody even bothered to calculate weights. I was way over whatever Ford had rated that poor truck for in ‘96.
But you are limited to farm use...(“Where ya headed with this giant camper and a truck with farm plates, son?” “The horse show, sir” )
#30
Funny story, I've been having some trouble with losing coolant somewhere in my 2014 F450 and I haven't been able to track the source down. EOT has been a little high, main indicator has been that the trans temp would climb about every 100 miles, especially when towing, and I'd have to add about 3/4 gallon of coolant to the radiator, not the reservoir, it would always still be full. So, I dropped it off at the mechanic and picked up.a 2016 F450 as a backup truck and now I've got one with the 19.5" tires. Boy are those suckers expensive. 😳. I think I like the 2016 better though, so it may be the primary and the 2014 will be the backup when they figure out the problem and I get it back. The 2016 has airbags as well and it definitely feels more stable when towing. We just bought a new ranch about 3 hours away so I couldn't afford to wait on the mechanic to figure it out, too much going on to be without the truck right now.
