Automatic brake pedal
Old Aug 18, 2020 | 05:31 PM
Jimmy nz's Avatar
Jimmy nz
I'm converting my 66 to automatic from manual will the automatic brake pedal fit as a straight forward replacement for the manual one .thanks
Old Aug 20, 2020 | 08:53 PM
William's Avatar
William
Yes, Grind off the welds for the smaller manual pad and add a junk yard pad with a new Ford rubber. Better if you can get the pedal bracket and arm from an automatic truck.
Old Aug 21, 2020 | 11:49 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
First year for a wider A/T brake pedal: 1973. There are several variations depending on which master cylinder/booster is present.
The brake and clutch pedal pads are the same: 1957/90's except with wider A/T pedal and some 1961/66 pedals that have round dot pedal pads.
Pokee
Aug 13, 2018 11:07 AM
jwreels
Sep 28, 2012 02:06 PM
