does it run?
Old Oct 20, 2003 | 04:20 PM
speedbird's Avatar
speedbird
does it run?
I recently aquired a 300ci six from a 83 f150. Im not sure it runs. How can I easliy check with resonable confidance before I put it in anything? I am not a mechanic, I just do the basics and learn as I go as well as cash limited. So taking it to a shop or going through it extensivly really isnt an option. Any advice?
Old Oct 20, 2003 | 04:26 PM
serving_time's Avatar
serving_time
Do a compression check on it. If this checks out good, then you should be able to get it to run.
Old Oct 21, 2003 | 02:49 PM
armyguy's Avatar
armyguy
put a 15/16 socket and breaker bar on the crank pulley and see if it`ll turn over, if it turns it`s a good chance it runs.. if it was maintained properly it may run damb good, only one way to find out so go for it!!
Old Oct 21, 2003 | 04:30 PM
bigreave's Avatar
bigreave
yeah pull the head and see how bad the cylinder walls. Or you can take out the plugs put a little brake fluid in the top of the cylinder and bump yor starter if it ant locked up it probaly will run.
