New to Ford World
Old Oct 20, 2003 | 04:05 PM
smokinvan's Avatar
smokinvan
New to Ford World
Hey all just got an 85 e-250 and was in search of some info. what kind of transmissions, rear ends and motors came in these things?
looking for some van information sites as well... not very lucky here.. any help would be greatly appreciated..
Thanks,
Jeb
Old Oct 20, 2003 | 06:04 PM
andym's Avatar
andym
You could get several different kinds of each. The motor could be a 300, 302 (if it's a light duty van) a 351W, or a 460. It could also be a 6.9L diesel. You didn't say whether the motor was an eight cylinder or not, or whether it's a diesel.
The transmission could be a couple different ones. You didn't say whether it was an automatic or a manual. It could be about 3 different kinds of each.
The rear axle is either a Dana 60 or a sterling 10.25 (not sure when they started with those - '85 seems about right) and it could either be a full floating or semi-floating axle.
Sorry I can't be of more help - post the door post codes for the tranny and rear axle and you'll get more information. Also post the VIN and we can tell you what motor you have. Assuming of course that nothing has been swapped out.
Old Oct 20, 2003 | 08:47 PM
smokinvan's Avatar
smokinvan
the rear end has 10 bolts in the cover ...the engine appears to be a 351W... the engine is a 3 speed......automatic...... what kinda tranny is this and what kinda rear end...what gears did it come with..
Any help is greatly appreciated..
Jeb
Old Oct 21, 2003 | 12:14 AM
andym's Avatar
andym
A three speed automatic is almost certainly a C6.
As for the rear gears, again, you will need to post the axle code from the door. You can also crawl under the truck as the ratio will be printed on a tag on one of the bolts. Do a search for it, and you will have an idea of what format the numbers are in.
There's no such thing as a 'stock' gear ratio. There are a lot of choices.
