Air bag compressor install location suggestions
Old Aug 14, 2020 | 11:59 AM
darrellbarnes's Avatar
darrellbarnes
I'm installing an Air Lift compressor today and looking for experiences on install location. I want to install as close to the driver position as reasonable to cut down on potential remote control connection issues.
Thanks.
Old Aug 14, 2020 | 12:26 PM
MBaldo's Avatar
MBaldo
Front of Bed
Old Aug 14, 2020 | 12:41 PM
darrellbarnes
Thanks. Have you had any connection problems with that location? I looked at that spot on my truck and it's nice and dry and no sign of splash up there.
Old Aug 14, 2020 | 12:43 PM
darrellbarnes
Another question............did you run to an upfitter switch or use the fuse tap? Thanks
Old Aug 14, 2020 | 01:18 PM
MBaldo's Avatar
MBaldo
My air bags come with a remote control. I have no issues with connectivity.
It works great, even with the compressor being on the passenger side.
Old Aug 14, 2020 | 02:03 PM
Lamoon78's Avatar
Lamoon78
Yes power it off a upfitter switch
Old Aug 14, 2020 | 02:16 PM
MBaldo's Avatar
MBaldo
I didnt put my AC on an uplifted switch, but it's not a bad idea.
Old Dec 5, 2020 | 06:00 PM
_hedge_'s Avatar
_hedge_
@MBaldo
I like that location you found for the compressor, where did you mount the controller/manifold? Pics would be ideal if you have any.
Old Dec 6, 2020 | 03:01 AM
paul100's Avatar
paul100
sorry I don't have a picture but for my 2020 F-450 I made my own bracket out of two long and two short pieces of aluminum angle. used the space in front of the fuel tank/fuel filter along side the the end of the tranny. There is a frame cross member there and I sandwiched the long pieces off the top with the short pieces on the bottom so no holes drilled in any existing truck components. The top rails are just below the bottom of the cab right inside the frame rail, basically under the drivers seat. Used four 3.25" long .25" stainless bolts to squeeze the 4 rails together its really hard to get wrenches up in there had to have my 12 yo get his small hands up there, LOL. I then hung the compressor and the manifold off of the two cantilevered out rails of the long pieces. I ran the power wire through the inside of the cross frame to the passenger side and then up behind the wheel well liner in to the engine compartment and connected to the #6 upfitter. Did that back in March, had been working great, except I now have some issue with one side of the manifold not knowing what pressure it is at, currently waiting for a new manifold that the airlift guys are sending out under warranty.
Old Dec 6, 2020 | 06:37 AM
rprice32's Avatar
rprice32
Old Dec 6, 2020 | 06:51 AM
projectnitemare's Avatar
projectnitemare
Easily removable and out of the road splashes
Old Dec 6, 2020 | 10:05 AM
HRTKD's Avatar
HRTKD
Originally Posted by MBaldo
Front of Bed
@MBaldo, how did you get access to that area? Maybe I'm not looking at it right, but I don't know how you get into that space.
Old Dec 6, 2020 | 11:03 AM
_hedge_'s Avatar
_hedge_
That area is open from the ground, it's essentially where the fuel fill goes but on the passenger side if that makes sense... then he bolted the pump to the front wall of the bed. This is about the best area I've seen for weather protection.
I'm still considering mounting it in the cab but most seem to think that's a bad idea. I have snow and cold temps for over 6 months of the year so also may want it inside so the controller will still work in -20C.
Old Dec 6, 2020 | 11:18 AM
HRTKD's Avatar
HRTKD
Thanks. I'm having trouble wrapping my head around the orientation of the picture. It would help if I looked under my own truck I suppose.
Old Dec 6, 2020 | 11:24 AM
AZC's Avatar
AZC
There is a company out of Tucson that makes mounts for under the bed. I wouldn’t recommend in the cab or on the cab at all. As the pumps age they get noisy.
my viar was 15 yrs old when I sold my Dmax. Worked great up to 200psi but was noisy.
